| Author |
Message |
Ryno78
Vehicle: 84 Suzuki Sierra
 Posted: Thu Jan 14, 2021 8:58 am |
G'day,
Have an 83 Sierra. When accelerating/driving there is a deadset annoying squeak coming from under the car.
Appears to be close to directly under the front seats or close enough.
Put clutch in and roll and the noise goes away?
Any suggestions or ideas?
Cheers,
Geoff
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5943 Location: Northcliffe, W.A.
 Posted: Thu Jan 14, 2021 9:11 am |
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Thu Jan 14, 2021 9:17 am |
Thrust bearing Gbox out and replace Prob worth doing the rear main, gbox seal and clutch while your at it on an 83 model
_________________ ...
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Thu Jan 14, 2021 9:19 am |
That’s consistent with a uni that’s dry and close to failure.
sideways
 Posted: Thu Jan 14, 2021 9:24 am |
MrRocky wrote: Thrust bearing Gbox out and replace Prob worth doing the rear main, gbox seal and clutch while your at it on an 83 model Stuffed thrust bearing would make noise when the clutch is pushed in, the opposite to the problem OP is having.
Ryno78
 Posted: Thu Jan 14, 2021 10:51 am |
Thanks for that. I'll get the Uni's looked at. Thrust bearing also needs replacing unfortunately, a bought a lot of work
MrRocky
 Posted: Thu Jan 14, 2021 1:52 pm |
Never had a uni squeak normally metallic clink for me means too much play
Gwagensteve
 Posted: Thu Jan 14, 2021 5:42 pm |
Definitely heard them squeak... normally not that long before they let go
rexhunta
Joined: Sun Jan 26, 2014 9:03 am Posts: 212 Location: Leschenault, WA.
Vehicle: 2020 Vitara Turbo
 Posted: Fri Jan 15, 2021 6:32 am |
I had squeaky unis on the jack shaft. Sounds exactly like the problem he's having.
sideways
 Posted: Fri Jan 15, 2021 9:35 am |
Yeah I've had them squeak like OP is saying. Both times just 1/4 of the uni was dry and there was no play.
