It is currently Mon Sep 21, 2026 2:02 pm
Vehicle: 84 Suzuki Sierra
Post Posted: Thu Jan 14, 2021 8:58 am
G'day,
Have an 83 Sierra. When accelerating/driving there is a deadset annoying squeak coming from under the car.
Appears to be close to directly under the front seats or close enough.
Put clutch in and roll and the noise goes away?
Any suggestions or ideas?
Cheers,
Geoff
Post Posted: Thu Jan 14, 2021 9:11 am
Unis?
Post Posted: Thu Jan 14, 2021 9:17 am
Thrust bearing
Gbox out and replace
Prob worth doing the rear main, gbox seal and clutch while your at it on an 83 model
Post Posted: Thu Jan 14, 2021 9:19 am
That’s consistent with a uni that’s dry and close to failure.
Post Posted: Thu Jan 14, 2021 9:24 am
MrRocky wrote:
Thrust bearing
Stuffed thrust bearing would make noise when the clutch is pushed in, the opposite to the problem OP is having.
Post Posted: Thu Jan 14, 2021 10:51 am
Thanks for that. I'll get the Uni's looked at. Thrust bearing also needs replacing unfortunately, a bought a lot of work :)
Post Posted: Thu Jan 14, 2021 1:52 pm
Never had a uni squeak normally metallic clink for me means too much play
Post Posted: Thu Jan 14, 2021 5:42 pm
Definitely heard them squeak... normally not that long before they let go
Vehicle: 2020 Vitara Turbo
Post Posted: Fri Jan 15, 2021 6:32 am
I had squeaky unis on the jack shaft. Sounds exactly like the problem he's having.
Post Posted: Fri Jan 15, 2021 9:35 am
Yeah I've had them squeak like OP is saying. Both times just 1/4 of the uni was dry and there was no play.
Users browsing this forum: No registered users and 32 guests
