It is currently Sun Aug 09, 2026 10:01 pm
Vehicle: 1988 US Samurai
Post Posted: Mon Mar 20, 2017 5:34 am
Did the g13bb in Jimny come with a crank position sensor? I ask because all of the g13bb motors in United States had one, but our version of the Jimny got the axe in 1996. When i look at G13bb oil pans on AU ebay they don't have a hole for the crank position sensor.
Post Posted: Mon Mar 20, 2017 6:52 am
G13bb's don't have the crank position sensor.
If you need a rwd pan with a crank position sensor I believe late x-90's and GV 1.6's work. I have seen a late efi vitara (circa 1997 or thereabouts) with a crank sensor sump but no sensor installed. Otherwise it's a cut and shut job
Post Posted: Mon Mar 20, 2017 8:17 am
Check megazip.
They should list a sump with ckp sensor hole.
I would look, but not at a pc atm.
Post Posted: Mon Mar 20, 2017 10:46 am
I think some spain built convertables run g13bb with crank sensors
Post Posted: Mon Mar 20, 2017 12:48 pm
The 1.6 pans fit. But when i bolted it up it had clearance issues with the front axles. My Samurai is almost stock height, just a set of OME springs.
Do your g13bb have a distributor? It doesn't seem like the cam position sensor alone would have enough resolution to do coil packs, even wasted spark.
Post Posted: Mon Mar 20, 2017 12:53 pm
jdk81 wrote:
Check megazip.
I've never seen megazip before. is it pretty reputable?
Post Posted: Mon Mar 20, 2017 1:06 pm
bb has a camshaft position sensor.
Coil pack balenos have both cam and crank.
Sounds like you're going to need to cut and shut a pan.
Post Posted: Tue Mar 21, 2017 1:28 am
Maybe I'm a bit slow, but you're saying that g13bb have a cam position sensor, no crank, and coil packs?
I have a modified pan. I've had it off twice now due to leaks, but I think I have it on leak free this time....
Post Posted: Tue Mar 21, 2017 5:50 am
Correct. Although as has been pointed out it seems that some (all?) convertible jimny's, which were made by Santana in Spain, are g13bb's with both.
Convertibles are rare here however.
Users browsing this forum: No registered users and 95 guests
