It is currently Tue Oct 27, 2026 3:39 am
Post Posted: Sun Jun 06, 2010 12:40 pm
Hey guys a mate of mine is in the middle of a GTI conversion in his old mans sierra and can't get injector pulse or spark.
He doesn't know what series motor it is either so can't tell you what that is, is running standard ecu and has had dizzy checked out and it's ok.
Got us baffled any help appreciated :wink:
TWIN LOCK IT & JUST DRIVE!
Post Posted: Sun Jun 06, 2010 12:57 pm
this might or might not help
http://auszookers.com/index.php?name=Fo ... &start=150
jimbo_jones wrote:
steknig wrote:
Nice work jimbo! look's a bit busy under there.
Did the auto lecy's say what was wrong with the harness?? :please:
there was a brown/white wire that had to be connected to the - of the coil to give a pulse to the computer so it knew the motor was running I still need to make up a speed sensor though
Post Posted: Sun Jun 06, 2010 1:17 pm
make sure everything that needs to be earthed is, that is what i found when i couldnt get injector pulse 1 pissy little earth. Get the pinouts for the ecu and test then follow every wire to make sure it is correct.
The ecu i got with mine was fried from the previous owners attempts at wiring it up, of course i spent days trying to figure out the problem before i got another ecu to try and bingo.
On baleno ecu's if you are not sure of the pinouts on the diagram you can remove the ecu cover and they are written on the circutboard, not sure bout gti's.
painstaking yes i know but foolproof.
Post Posted: Sun Jun 06, 2010 10:05 pm
what dizzy is he useing?
is the afm seperate from the intake.. if it is its mrk2/3 if its not mr1
Post Posted: Sun Jun 06, 2010 11:46 pm
Dizzy is out of the coily zook it was in. I think the afm is seperate.
Post Posted: Mon Jun 07, 2010 9:57 am
i can help you with this but you have to be more specific , does the afm bolt to the throttle body or not ? take some pics and post.
if you can take some pics of the cylinder head between the intake manifold and the thermostat housing , or the timing belt with the top cover off , or the intake manfold and throttle body , i can tell you what years your engine was from ...
does the fuel pump prime when you turn the ignition on ? if it does you have a problem with the crank angle sensor most likely , the ecu wont fire injectors without a cas signal. if it doesnt prime , its most likely a power or earth problem to the ecu.
alternitavely if you post the "33920-xxxxx" part number of the ecu i can identify your setup and can help you locate the problem easier ..
Post Posted: Mon Jun 07, 2010 10:56 am
Cheers for that i'll get them up asap.
Post Posted: Mon Jun 07, 2010 11:11 am
how it the dizzy mounted?
its not exactly a straight bolt on.... if it is a sierra..
this is a mk1 with sierra dizzy
does it look like this??
Post Posted: Tue Jun 08, 2010 8:09 am
Thats all i have at the moment guys hope that helps.
Post Posted: Tue Jun 08, 2010 8:54 am
Mk1
ok i had the same issue... is the fuel pump switching on?
is the fuel pump reley hooked up though the computer?
Post Posted: Tue Jun 08, 2010 9:09 am
Fuel pump triggered by a diferent source.
Post Posted: Tue Jun 08, 2010 9:11 am
it's the ecu not firing up no inj pulse with noid light fitted and no spark thats what my mate just told me.
Post Posted: Tue Jun 08, 2010 10:49 am
well the spark should run though the standard wiring for the car??
pm me and i will give you my number i had hell getting mine to go, your mate can call me.
Post Posted: Tue Jun 08, 2010 11:02 am
swap the plug for the mass air flow sensor with that of the throttle position sensor and see if it fires. mk1's have the same plug for these two items.
Post Posted: Wed Jun 09, 2010 9:12 am
i think the problem is in the wiring to the fuel pump.... the computer has to switch a relay (fuel pump circuit) or u get no injector pulse.
i sent a pm with my number, waiting on the call....
Post Posted: Wed Jun 09, 2010 10:26 am
Have passed the number on mate he will call you :wink:
Users browsing this forum: Google [Bot] and 235 guests
