It is currently Fri Oct 30, 2026 1:28 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
Post Posted: Mon Sep 27, 2010 3:22 am
Smoothly taking off at traffic lights (2wd) then planting the right foot once I was moving, when the old lady in the car next to me heard the bang I swear she nearly shat herself
Post Posted: Mon Sep 27, 2010 9:33 am
You do ask quite a lot of your Sierra driveline with all the ponies you're pumping through it with your set-up though ;)
I want my old sig back :(
Vehicle: Suzuki Sierra
Post Posted: Mon Sep 27, 2010 11:20 am
joeblow wrote:
the main problem is you have all that torque going through the t/case......yet the tailshafts and diffs are still having a hard time turning the wheels as they did before transfer gears, its just that everything forward of the t/case is having it easier. diff gears would help solve alot of the drama there.
Perhaps an investment in an auto as well....and some diff gears...and some fully hektic suspension....and anti gravitational shocks...
The sand would theoretically load up the diffs, at 6,000rpm in high first the other option is that someone backed off the gas way too quick without pushing the clutch causing a compression like lock up.
Post Posted: Tue Sep 28, 2010 5:06 am
ok, case and gears have arrived just gotta get of my butt and fit/mount em. Im still going to use the low range cradle, with the top half of the roc ring holding all the un held bolts.
Users browsing this forum: No registered users and 379 guests
