It is currently Sun Nov 01, 2026 2:53 pm
Post Posted: Tue Nov 09, 2010 11:45 pm
my car never goes when i want it to :( . it is literally a piece of shit. makes me so frustrated
the car was working pefect the other day. i put new oil in it. as well as a new oil filter. now its blower alot of smoke, spark plugs are always going black, my guess is need new rings or valves. some thing like that
after all that ive discovered, theres sometimes spark, some times not at all, coil pack maaby? ive checked dizzy, clean all point, rotor button, new leads, clean plugs. still no change
when it does wanna go, when its cold it only starts when u let go of the key, WTH :? but when its fairly hot it starts normal, some times when you let go still. strange to me :?
dis morning when i went to start it, to see if there was a change. nothing :( but now the burnt gases and smoke are coming out of carby, nothing is coming out of the exhaust its cold as and the carby is boiling hot
has my engine finally past away. please help my lump of crap :D
thanks Aaron
Post Posted: Wed Nov 10, 2010 12:13 am
Get a 1.6 EFI... Problem solved.
Post Posted: Wed Nov 10, 2010 12:17 am
ive got a 1.6 carby
Post Posted: Wed Nov 10, 2010 1:15 am
efi is better ;) :D
Post Posted: Wed Nov 10, 2010 1:44 am
sure is, would be less problems. ill turn it to efi later on down the track :). so no one can help. ill just figure it out my self
thanks
Post Posted: Wed Nov 10, 2010 1:46 am
What color smoke? Black?
Lil Foot!
Vehicle: Suzuki
Post Posted: Wed Nov 10, 2010 1:49 am
thanks
Give it some time, You only posted 2 hours ago, People do work and don't live on the forums during the day..
Post Posted: Wed Nov 10, 2010 1:55 am
bluey/grey
Post Posted: Wed Nov 10, 2010 3:02 am
put in too much oil?
Post Posted: Wed Nov 10, 2010 3:07 am
I'll post some helpful info tonight, i can't now i'm at work =P
But dw, its EASY FIX
Post Posted: Wed Nov 10, 2010 4:01 am
its not quite full, so i havnt over filled it
Post Posted: Wed Nov 10, 2010 6:16 am
going by the dipstick, or the oil cap? :lol:
Post Posted: Wed Nov 10, 2010 6:23 am
dipstick :D
Post Posted: Thu Nov 11, 2010 1:09 pm
when you say it only starts when you let go of the key do you mean it only fires then? that the starter works normally..
if this is happening check the wiring to your coil, there should be a wire that is energized when you are cranking and then it get its feed when the key returns to the run position.
A worn out ignition switch will cause this behaviour and is usually hard to trace as its intermittent..
the hot carby thing sound weird, is the heat from the heater hoses running up to the carby choke or from somewhere else?
Post Posted: Thu Nov 11, 2010 10:19 pm
i know its not the problem, but what sort of fuel you running aswell?
Post Posted: Fri Nov 12, 2010 12:45 am
the car fires up when i let go the key and it returns to run. so im thinking its some thing to do with the coil or barrel. starter motor is working fine
heater hoses are blocked off, not the original carby. there was like gases or smoke coming out of the carby enough to blow my filter off. carby was really hot, exhaust was cold.
did a oil change again after 5 days. oil that came out of the engine was black after 5days. change oil again still blowing smoke, im guessing its new valves and valve seating time :(. or i think i need to do valve clearances. one off my rockers are very loud. is this causing the grey smoke out of the exhaust cos one of the valve isnt closing properly :s
toeragz: i dont know what fuel. my car isnt on the road atm, so my mum went and got me it. mosly likely it'll be E10
Post Posted: Fri Nov 12, 2010 12:51 am
is the cat/exhaust damaged or collapsed?
Post Posted: Fri Nov 12, 2010 12:57 am
i wouldnt have a clue sorry, i was thinking of doing a exhaust upgrade very shortly though.
Post Posted: Fri Nov 12, 2010 3:01 am
just took the exhaust manifold off. looks like cylinder 3 is shot. theres black oil coming out off cylinder 3 exhaust port. started it up and it only blows grey/blue smoke out of exhaust port. taking a cylinder pressure test this arvo
does any one know what pressure it should be for g16a
Users browsing this forum: Google [Bot] and 156 guests
