| Author |
Message |
Marko_SJ
Joined: Tue Jan 17, 2012 1:40 am Posts: 2979 Location: Darwin, NT
Vehicle: WT sierra, GU CRD
 Posted: Wed Sep 18, 2013 2:43 am |
^^ I reckon I would have been right provided I did what sideways suggested.
_________________ I love ZD30. :)
Jonno
Joined: Sat Aug 29, 2009 11:30 pm Posts: 47 Location: Melbourne
 Posted: Thu Sep 26, 2013 1:41 pm |
Not sure if VSI 20 is still current but in answers to common questions (Jan 2000) under Q11 it states: Q11: Doors - My four wheel drive has removable doors, can i leave them off when driving? A: VicRoads strongly recommends against this practice, particularly when the vehicle is used on the road. However, if seatbelts are fitted the vehicle may be used without the doors fitted. I guess the two areas that might fault this is if this has been superseded but I am not sure how to find that out and what defines "removable" ie is needing screwdriver ok? If you cut your hinges neatly I suppose you could argue that they came like that and then it is a tool less exercise http://www.vicroads.vic.gov.au/NR/rdonl ... /VSI20.pdfI am not suggesting no doors is the best idea on the hwy, but if they arent required I suppose it opens up the possibility making our own half doors that just need to comply with the hinges and latching requirements to be legal
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Thu Sep 26, 2013 3:43 pm |
Removable is pretty well only applicable to cars with canvas doors, and jeeps which have the slip-off hinges.
using a tool to remove them doesn't make them removable =) if you applied that logic any car has removable doors!
Marko_SJ
 Posted: Thu Sep 26, 2013 3:50 pm |
alien wrote: Removable is pretty well only applicable to cars with canvas doors, and jeeps which have the slip-off hinges.
using a tool to remove them doesn't make them removable =) if you applied that logic any car has removable doors! But what tool shep wrote: I have some [sierra doors] but I cut the bits off that rattle
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Thu Sep 26, 2013 5:24 pm |
But certain models of Sierra and LJ had cut hinges from the factory. Right?
Jonno
 Posted: Thu Sep 26, 2013 6:54 pm |
It doesnt state that it has to be done without any tools in that document. The fact that suzuki use philips screws and have external hinges should go a long way to prove that they were designed to be easily removed. If there are any suzuki manuals that reference door removal I think that would also be very helpful.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13015 Location: Melbourne
 Posted: Thu Sep 26, 2013 7:13 pm |
Annoyingly, that document doesn't really clarify anything.... And we go around in circles again.
The engineer we are working with says no, so that looks like a no. The conversations I've had with friendly police officers about running doorless was along the lines that a less friendly officer wouldn't care what you said, they'd defect the car and let you sort it out.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Thu Sep 26, 2013 7:21 pm |
Jonno wrote: The fact that suzuki use philips screws and have external hinges should go a long way to prove that they were designed to be easily removed. Have you ever tried removing the hinges with a mere phillips head screwdriver on hinges that have never been removed?
_________________ mlm
greenzook89
Joined: Sun Sep 06, 2009 11:30 pm Posts: 2591 Location: Ipswich
 Posted: Thu Sep 26, 2013 7:24 pm |
SierraDan wrote: Jonno wrote: The fact that suzuki use philips screws and have external hinges should go a long way to prove that they were designed to be easily removed. Have you ever tried removing the hinges with a mere phillips head screwdriver on hinges that have never been removed? Yes It Sucked
Marko_SJ
 Posted: Thu Sep 26, 2013 8:43 pm |
SierraDan wrote: Jonno wrote: The fact that suzuki use philips screws and have external hinges should go a long way to prove that they were designed to be easily removed. Have you ever tried removing the hinges with a mere phillips head screwdriver on hinges that have never been removed? He knows, this man knows....
