| Author |
Message |
shaz
Vehicle: 1993 vitara lwb
 Posted: Sat Aug 13, 2016 11:21 am |
Please help!! I have 1993 vitara lwb, Has a g16b efi engine in it. Around a month ago the engine got a little wet (Seriously only a little) Ever since it has beeing missing low down in the revs, I've changed leads, Plugs, Distributor, Done a compression test, Any help as to what the cause might be? Its using more fuel due to this, It also seems to be a little slower (could just be me thinking that though) Thanks!!!
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Sat Aug 13, 2016 2:41 pm |
Where did it "get a little wet" - externally, or in the intake?
shaz
 Posted: Sun Aug 14, 2016 6:09 pm |
May have been the intake, Im not 100% sure as i wasn't driving it at the time.
Gwagensteve
 Posted: Mon Aug 15, 2016 7:39 am |
How do you know it only got "seriously only a little" wet?
shaz
 Posted: Mon Aug 15, 2016 8:08 am |
I was there, the car literally went through the hole, splashed water up, when the driver pulled up, I popped the bonnet and there was no water anywhere near the top, just a bit dripping from near the engine cross member and bottom of the radiator.
Gwagensteve
 Posted: Mon Aug 15, 2016 9:32 am |
Oh OK. Check for water in the intake - does it have the old style AFM? (big cone) could be the AFM or its connections got wet
jono165
Joined: Thu May 27, 2010 12:01 pm Posts: 834 Location: Melbourne
 Posted: Mon Aug 15, 2016 2:14 pm |
Don't g16b's run funny when the rank key way is worn? The symptoms you have may be unrelated to the water. Just a coincidence it's happened at the same time.
shaz
 Posted: Mon Aug 15, 2016 6:38 pm |
well it didn't actually start directly after the water, It happened around an hour or 2 later but i just sorta asumed that may have been the reason?
