It is currently Mon Jul 27, 2026 11:46 pm
Vehicle: 1993 vitara lwb
Post Posted: Sat Aug 13, 2016 11:21 am
Please help!!
I have 1993 vitara lwb, Has a g16b efi engine in it.
Around a month ago the engine got a little wet (Seriously only a little)
Ever since it has beeing missing low down in the revs,
I've changed leads, Plugs, Distributor, Done a compression test, Any help as to what the cause might be?
Its using more fuel due to this, It also seems to be a little slower (could just be me thinking that though)
Thanks!!!
Post Posted: Sat Aug 13, 2016 2:41 pm
Where did it "get a little wet" - externally, or in the intake?
Post Posted: Sun Aug 14, 2016 6:09 pm
May have been the intake, Im not 100% sure as i wasn't driving it at the time.
Post Posted: Mon Aug 15, 2016 7:39 am
How do you know it only got "seriously only a little" wet?
Post Posted: Mon Aug 15, 2016 8:08 am
I was there, the car literally went through the hole, splashed water up, when the driver pulled up, I popped the bonnet and there was no water anywhere near the top, just a bit dripping from near the engine cross member and bottom of the radiator.
Post Posted: Mon Aug 15, 2016 9:32 am
Oh OK. Check for water in the intake - does it have the old style AFM? (big cone) could be the AFM or its connections got wet
Post Posted: Mon Aug 15, 2016 2:14 pm
Don't g16b's run funny when the rank key way is worn?
The symptoms you have may be unrelated to the water. Just a coincidence it's happened at the same time.
Post Posted: Mon Aug 15, 2016 6:38 pm
well it didn't actually start directly after the water, It happened around an hour or 2 later but i just sorta asumed that may have been the reason?
Users browsing this forum: No registered users and 336 guests
