It is currently Fri Nov 06, 2026 11:34 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2
Post Posted: Wed Dec 22, 2010 6:45 am
At 4,1oo rpm it really gets loud and you can hear the headers sucking
Post Posted: Wed Dec 22, 2010 6:46 am
how do headers suck, i thought they're under pressure from compression?
Post Posted: Wed Dec 22, 2010 6:49 am
Sorry i mean It's sounds like they're sucking.
Post Posted: Wed Dec 22, 2010 6:54 am
its caused by the low pressure behind the high pressure pulse pushed out, and this is timed by the tuned length of true extractors for that low pressure to be just ahead of a high pressure from another cylinder to suck it out further improving the scavenging effect, meaning your exhaust gasses are removed from the combustion chamber allowing for more goodness of petrol and air
Post Posted: Wed Dec 22, 2010 6:58 am
At 4,100rpm the main thing I can hear is the induction noise that having a snorkel causes, particularly if accelerating. :-)
Better than stock...but not by much.
 Profile YIM
Vehicle: Jeep
Post Posted: Wed Dec 22, 2010 7:16 am
X 2
Perfectly said ! :wink:
Post Posted: Thu Apr 07, 2011 3:11 am
BUMPIN an old thread. tell me, i've had a good read through this thread and another http://www.auszookers.com/index.php?nam ... ic&t=16398 - everything leads to "GO FOR IT!!!"
considering doing an upgrade; 2" / extractors / hi flo / muffler / pod filter
i guess price can vary between $750-$1000
is it really worth the money. is the performance gain enough to warrant spending up to 1k
thanks :D
Kelvin .: White 2004 Jimny JLX :.
Post Posted: Thu Apr 07, 2011 5:17 am
Probably not worth it...but I'd do it again in a heartbeat. :-)
 Profile YIM
Vehicle: 1985 Holden Drover
Post Posted: Thu Apr 07, 2011 6:38 am
That seems like quite a lot, might be cheaper getting the extractors and cat online than taking it to a shop to bend and fit the pipe?
1989 WT Sierra.
Vehicle: Jeep
Post Posted: Thu Apr 07, 2011 7:40 am
thanks :D
IMO, yes it is worth it. i have done an exhaust upgrade to every car i have owned, it just makes them run so much better, and gives you more high RPM get up and go, which is great for offroad, and onroad if you got a bit of a lead foot, ha ha...
So yeah, Do it, Do it, Do it !
But shop around a bit, even $750 sounds to much to me... you can get a good set of extractors off ebay for $200 with free delivery ! :wink: :D
Post Posted: Thu Apr 07, 2011 9:37 am
Yeah thats like i said, $200 for extractors off ebay, $100 max for a hi flow cat from the US. No way the rest will cost $700 :?
Post Posted: Thu Apr 07, 2011 9:48 am
Is your a a VVT jimny? the extractors tend to cost around $350-$400. Also if i was you i wouldn't GET a pod filter, as the jimny has a air sensor on the box, so a engine light might come on, if the senor is not connected. Just get a normal K&N panel filter. Cost around about $60.
Post Posted: Thu Apr 07, 2011 10:47 am
yeah wasn't sure about the pod idea. but i'll look into it further when the time comes. mines a non VVT too
with exh, all prices includes delivery; wildcat extractors about $275 / 100 cell hi flo cat $150 / sports muffler $150 thats $575
2" exh plus fitting for the lot would be minimum $200 easy. i'm thinking a bit more
thats why i've said $750 upwards.
not a fan of K&N monkey...will go for a dry type which doesn't need to be oiled.
Post Posted: Thu Apr 07, 2011 10:50 am
Ok. I got my 2" exhaust bent up for $80 including pipe, i just took in the old one and told them to copy it, and just cut of the old brackets and welded them on to the new peace.
Post Posted: Thu Apr 07, 2011 11:00 am
wow thats cheap. i'll go get some quotes.
Post Posted: Thu Apr 07, 2011 11:46 am
Go ebay mate, much cheaper!
Users browsing this forum: Google [Bot] and 69 guests
