It is currently Fri Oct 30, 2026 12:07 am
Post Posted: Tue Aug 31, 2010 6:26 am
i have a suzuki sierra with a 1.6 conversion carby i have front hilux diff and rear bundarah diffs sprung[i] i would love some more power would i go reduction gears and charger can any one help me and i have a slight vibration when driving would doulble cardanal joint fix this thanks :roll:
Vehicle: MY2019 Jimny
Post Posted: Tue Aug 31, 2010 7:20 am
What size tyres you have?
hey mate your a bit vage...
so u have a 1.6 carbi
lux diffs
what is your tail shaft angles like?
what condition is the motor in?
whats moddle is the zook? most zook transfers can have rock hoppers fitted.
Post Posted: Tue Aug 31, 2010 7:42 am
As has been said, there's nowhere near enough information in your post to help.
I'm not being a grammar/spelling nazi but your post is pretty hard to understand too.
What axle ratio are you running?
What transfer case are you running?
What tyre size are you running?
(if road driving is important) what are your cruise revs? (@ 100km/h)
How is the suspension set up? How tall is the car (a photo might help here)
What do you use the car for? (i.e do you need more power on road or off road?)
A double cardan joint in the rear tailshaft might help with vibration, but to get one to work properly you might need to roll the rear differential. for a double cardan shaft t work you will need to point the rear diff at the transfer so the uni at the diff has no angle. All the angle must be borne by the cardan joint or you will still have vibration, so it might be an expensive/complex item to fit.
As per every other thread about turbo/supercharging, it's not cheap and the learning curve can be expensive. Adding boost to a carby G16 to try and fix a gearing problem is a bad idea. (It's actually an expensive way to fix a gearing problem - gearing a sierra transfer case is cheap)
PS - You'll notice I've really just asked a whole bunch more questions. You need to provide as much information as possible when you ask for help so we can provide helpful advice. It's a slow and difficult process to draw out what we need to know to help you out.
Vehicle: LJ20 LJ50
Post Posted: Tue Aug 31, 2010 7:54 am
What????
are you calling him a vag???? (vagina)
are you calling him a vegetarian??
or do you mean vague??????
Camels have nice toes
Post Posted: Tue Aug 31, 2010 8:10 am
TZAR wrote:
What????
I think he was trying to call him a vagina. Can't be sure though. :?
Post Posted: Tue Aug 31, 2010 10:40 pm
ok its runing 32 inch tyers on 16 inch custom 4 inch dish eg rodaeo wheels flipd and wellded standard ratio in diffs it has 2 inch lifted rockhopper springs motor was rebuilt 2000 ks ago its a 87 model sierra standard tailshaft standard fron tailshaft from what i can c it has spacers in the front shaft
Post Posted: Wed Sep 01, 2010 12:37 am
Hilux's had several different STANDARD ratios.....
Vehicle: 1987 sierra tray back buggy
Post Posted: Wed Sep 01, 2010 12:54 am
the ratio in mine is 4.1 i donjt think this helps tho.
engine mods
extractors and a sport system
intake ie k&n (might help)
nos injection
bigger better carbi
get some reduction gears they are awesome.
put sierra diffs back in it coz you dont need lux diffs with 32's
Post Posted: Wed Sep 01, 2010 1:01 am
Big block V8! :D :D
:roll:
I want my old sig back :(
Post Posted: Wed Sep 01, 2010 1:44 am
Is it green 8O
it does make a difference
Post Posted: Wed Sep 01, 2010 1:57 am
RIKSTR wrote:
Is it green 8O
definitely. mine gained 30hp when i went from green to orange. :wink:
Post Posted: Wed Sep 01, 2010 2:21 am
RIKSTR wrote:
Is it green 8O
Wouldnt it be the dust you washed off before the spray job? Did you even wash the dust off?.. :lol:
Post Posted: Wed Sep 01, 2010 2:28 am
RIKSTR wrote:
Is it green 8O
yeah i had to wash it because it was covered in salt from the boat trip to darwin.
Post Posted: Wed Sep 01, 2010 6:18 am
RIKSTR wrote:
Is it green 8O
I spraypainted my car after it had been sitting in the shed for a week after a day playing in serious clay/mud
It looked sick! All rugged and the like
Then Dad told me i was an idiot lol, so i washed it off with a Gurney :D
Users browsing this forum: Google [Bot] and 138 guests
