It is currently Mon Nov 02, 2026 10:30 am
Post Posted: Mon Sep 27, 2010 6:37 am
Is their an easy way to remove these little plastic thingys so I can fully strip the door?
Don't know why but I'm struggling with something that should be simple. :cry:
SS
Post Posted: Mon Sep 27, 2010 6:46 am
The lock one unclips from the rod then the rod can be pulled out. The other one may not come apart in one piece, can you disconnect it somewhere else?
Post Posted: Mon Sep 27, 2010 7:17 am
when i replaced my door handle i used needlenose pliers to destroy it to get it off... while trying to destroy it though it somehow pulled through unharmed! haha
Post Posted: Mon Sep 27, 2010 7:36 am
Yep that sound's about right.. :lol:
Post Posted: Mon Sep 27, 2010 7:48 am
Dave for the first pic... Stick a large flat blade screwdriver between the black plastic and the rod and twist it. The rod will pull out of the red bit.
The second one you use a small flat blade and open the green clip and then pull the rod out of it.
Post Posted: Mon Sep 27, 2010 8:07 pm
Thanks guys i was going about it the wrong way.
Frustrating sometimes when you know it should be simple but just not happening. :oops:
SS
Users browsing this forum: No registered users and 84 guests
