It is currently Fri Nov 06, 2026 6:42 pm
Post Posted: Thu Jun 16, 2011 11:10 pm
Ok building a buggy for Tuff Truck dropping the 1.6 into a 92 sierra and want to run the stronger vitara 5spd.
Dose anyone make an adaptor to remove the vitara transfercase and just run the divorced sierra one
Duncan
Post Posted: Fri Jun 17, 2011 1:41 am
give locked up a call thay sell a kit so you can run you standard jack sharft from a vitara auto so i,m gessing they would do something for the 5spd
Wardy
I'm busy,your ugly,have a nice day
Post Posted: Fri Jun 17, 2011 1:47 am
check out JML Gear in the business directory, joeblow has a similar set up to whats available from locktup for the auto, not sure how much work it would be to adapt to a manual.
http://www.auszookers.com/index.php?nam ... ic&t=20147
Post Posted: Fri Jun 17, 2011 3:11 am
You don't need any of these for manual transmissions, they have a sealed and supported output.
still give the cash if you like though :wink:
Post Posted: Fri Jun 17, 2011 10:26 am
So if I drop the vitara transfercase of then the jack shaft is the same size and spline count as the out put of the vitara 5spd that would be cool.
Post Posted: Fri Jun 17, 2011 10:40 am
This is the back of the 5sp. Just drop the transfer off and shove the jack shaft up its arse :lol:
Post Posted: Fri Jun 17, 2011 11:54 am
yeah should bolt straight up, maybe new mounts for the box and some tunnel work.
Post Posted: Sat Jun 18, 2011 12:23 am
Is there a seal already in the out put of the vit 5spd were the jack shaft will go in and whats the large bottom hole for.
Post Posted: Sat Jun 18, 2011 2:35 am
i guess this answers your question, im not sure about the lower hole. im sure someone will.
Post Posted: Sat Jun 18, 2011 2:40 am
In the pic I posted, that hole supports a shaft from the transfercase. I have left the front of the transfer on there so that I can run the seal (sits around the splined shaft and slip yoke of a jackshaft)
The hole at the bottom just needs to have a welch plug tapped in to seal it :wink:
Post Posted: Sat Jun 18, 2011 5:25 am
Thank you so much will be going this way then stronger box and bigger clutch.
Users browsing this forum: Google [Bot] and 56 guests
