It is currently Sat Nov 07, 2026 3:37 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
Post Posted: Wed Jul 13, 2011 2:52 am
Hi guys,
How is everyone?
I wanna know what diff is better to fit to a vit? The Calmini Anvil, or the steel gv diff.
What are the positives and negatives of both?
Thanks guys
Post Posted: Wed Jul 13, 2011 2:58 am
with the anvil you still need to get the steel pinion carrier from a GV otherwise you're stuck with the stock alloy one & you'll have trouble finding a wrecker willing to sell you half a diff.
Post Posted: Wed Jul 13, 2011 3:02 am
Would you be able to use a Sierra carrier?
Post Posted: Wed Jul 13, 2011 3:17 am
yeah, but there are a few hurdles... no pinion mount for starters & then there is the crossmember clearance issue due to the amount of diff drop is built into the calmini anvil.
Timbo_ is running the sierra carrier in an anvil & had a few dramas trying to get it all to work & i'm not sure if it's even back on the road yet.
Post Posted: Wed Jul 13, 2011 3:20 am
i spoke to timbo last night and he has finally seen the light and is buying a sierra :peaceout:
Post Posted: Wed Jul 13, 2011 3:27 am
as long as it's not a coily, cause that would be a step backwards.
Post Posted: Wed Jul 13, 2011 3:38 am
thats generous, i reckon it would be a massive leap backwards. :lol:
Post Posted: Wed Jul 13, 2011 6:31 am
A coily rear diff housing would be a great option for this. it would be easy to use the mounts that are already there to fix to for a pinion mount.
Major issue would be its from a Coily
Post Posted: Wed Jul 13, 2011 6:35 am
http://auszookers.com/index.php?name=Fo ... ight=anvil
Post Posted: Wed Jul 13, 2011 9:47 am
Pretty sure that Calmini state the anvil has to be used with a 3" lift minimum also!
Virgil the Vitara
SV620 Estate
Post Posted: Thu Jul 14, 2011 1:25 am
Thanks guys, looks like I'll need to find a steel gv front diff either way, ive got the cal 3" lift :)
Matty
Post Posted: Wed Sep 14, 2011 10:17 am
Didn't think it was worth starting a new thread so I'll ask it here... would I be right in assuming the Calmini Anvil won't suit the SV model Vitaras as the diff drop brackets are different compared to the earlier models (and on the Anvil they are welded on - not bolt on)?
Moses' SQ625 GV Pig
Post Posted: Wed Sep 14, 2011 10:35 am
correcto :cry: :(
Post Posted: Wed Sep 14, 2011 12:08 pm
Couldn't you just cut and shut the welded on brackets to the anvil in the same way you would if they were the bolt on brackets?
Go Hard, Trailer Home
Post Posted: Wed Sep 14, 2011 12:14 pm
i can't weld :oops:
Post Posted: Wed Sep 14, 2011 12:17 pm
i can't weld :oops:
Buy one and send it to me 8)
Post Posted: Wed Sep 14, 2011 12:29 pm
just make a TSOR one. :wink:
Post Posted: Wed Sep 14, 2011 12:31 pm
When do you want it by? :lol:
Post Posted: Wed Sep 14, 2011 12:42 pm
I did think about it, but without a steel GV 3rd, whats the point? :?
Anyone with a steel GV 3rd will have a steel housing aswell.
Can you use a rear sierra 3rd if you sorted out a pinion mount? :?
Post Posted: Wed Sep 14, 2011 12:56 pm
i can't weld :oops:
You don't need an anvil :roll:
Post Posted: Wed Sep 14, 2011 12:57 pm
I could do with one for the lowrider, once my swb is finished :wink:
Vehicle: 96 LWB Vit
Post Posted: Wed Sep 14, 2011 9:54 pm
The main difference between the anvil and the GV housing (apart form the built in diff drop brackets) Is that the anvil already has a bearing carrier & shortened axle for the RH side, so you can run a LH side CV on the RH Side.
Makes trackside changes of your CV's a lot quicker & easier.
Buddies
I can't leave well enough alone....
Post Posted: Wed Sep 14, 2011 11:00 pm
Want a bolt on part? buy a grand vitara steel diff..
Want a head fuck trying to fit this giant piece of steel under your car with huge arms sticking out of it?
buy and anvil.
I have to put the sierra 3rd in, then try and bolt up the anvil around it is so large.
But im young and dumb and still will go anvil.
I Just wanted to save a heap of cash and use a sierra housing for the fact evey man and his dog has one in thier back yard. I managed to get one off shep with a lockright it too.
no one in their right mind would do so.
Post Posted: Wed Sep 14, 2011 11:15 pm
Timbo, I think the sierra 3rd caused you more problems than it normally would with a GV 3rd.
Buddies, nice work... i completely forgot about the stub axle set up on the avil. :oops:
Vehicle: 96 LWB Vit
Post Posted: Wed Sep 14, 2011 11:33 pm
Cheers.
I know what timbo is saying about installing one of these things with the brackets already in place. I tried to do it after my front diff rebuild, it doesnt work. Ended up having to pull the drop brackets off.
The bearing carrier and stub axle mod is a Must in my opinion. I've had to replace 2 cvs trackside now, literally a 10 minute job.
Next mod on the agenda now is the hilux cv conversion.
Buddies
Post Posted: Wed Sep 14, 2011 11:35 pm
so you can use a sierra center????
Please explain???
Stocker
Post Posted: Wed Sep 14, 2011 11:54 pm
So a GV Steel diff is a straight change over on a 1.6 carby (92) vitara??
I will only be getting a 2" lift, so from what I can figure the anvil won't work.
it can be done, you need to fashion some sort of pinion mount.
christover had a thread going about the sierra carrier, but ended going with the GV, will try & dig it out.
IDJIT: i think these are the ones im talking about.
http://auszookers.com/index.php?name=Fo ... rra+vitara
http://bbs.zuwharrie.com/content?topic=100689.0;all
Post Posted: Thu Sep 15, 2011 12:10 am
Guys I can't find a steel diff. So what are my other options?
Post Posted: Thu Sep 15, 2011 12:23 am
I know where there is one set up with 5.12's ready to roll.
what are you willing to pay? that is the 1 billion dollar question seeing they're so "hard" to get these days...
Users browsing this forum: No registered users and 50 guests
