It is currently Sat Nov 07, 2026 12:38 am
Post Posted: Tue Aug 16, 2011 5:14 am
I have heard you can remove dents from fuel tanks using compressed air but I am not sure how? Could someone enlighten me as to how it is done? :)
Post Posted: Tue Aug 16, 2011 5:29 am
Easy, remove fuel cap and fuel filter. Make sure the tank is empty first by pressurizing the tank through the inlet and catching fuel underneath by a fuel safe container.
Once the tank is empty, block the fuel outlet with a screw and a hoseclamp.
Now pressurize the tank with your compressor until you start hearing donk, donk! Dents are popped out and life is good.
I used a blower nozzle on my compressor and wrapped the head in a rag to seal when in the fuel inlet. I used a rag to eliminate the chance of over pressurizing the tank and doing damage.
Post Posted: Tue Aug 16, 2011 7:10 am
X2
but be carefull its easy to over pressurise the tank and blow the seams.
I'd use a regulator and just keep upping it slowly so you dont endup trying to blow it out at 120 psi
Post Posted: Tue Aug 16, 2011 8:47 am
How much pressure will it take to pop the dents out roughly? And can I do it with the same compressor I use for pumping up tyres after wheeling?
Post Posted: Tue Aug 16, 2011 8:58 am
yes you can if you can seal it well enough.
30 psi should be shit loads for most dents, I bet most will pop at less than 20 psi
Post Posted: Tue Aug 16, 2011 9:49 am
Ok, hopefully it doesn't explode :lol:
Post Posted: Tue Aug 16, 2011 12:25 pm
Use patience and a steady trigger finger if a regulator is not fitted.
Vehicle: 03 Jimny
Post Posted: Tue Aug 16, 2011 12:48 pm
X2 be very light on the trigger. Didnt take much air to crack the bottom of my tank
Post Posted: Tue Aug 16, 2011 9:46 pm
I filled my tank with water, then pressurised the tank with air. Worked really well...
Post Posted: Tue Aug 16, 2011 9:50 pm
Couldn't you pop the dints out the same way you set the bead on a tire, a bit of start ya bastard and matches :lol:
p.s, can we grab a video if you decide to try this method!
Vehicle: Daisy
Post Posted: Tue Aug 16, 2011 10:10 pm
If we're still talking about a fuel tank, he probably won't even need the start ya bastard!
Don't do it that way though, it would end in tears!
Post Posted: Wed Aug 17, 2011 12:56 am
You would have to be fuckin dumb to even consider that idea :roll:
Post Posted: Wed Aug 17, 2011 1:21 am
awesome tech VW Dave? :roll:
Post Posted: Wed Aug 17, 2011 2:05 am
What's the idea of putting water in it?
Post Posted: Wed Aug 17, 2011 2:14 am
i guess it's less volume to fill with air
Post Posted: Wed Aug 17, 2011 2:24 am
Less air, More weight on the dents.
Just air would do the same. I should try it gradually on the coily tank i have here :D
If it blows up it blows up, Dont really care, been sitting here for years :lol:
Post Posted: Wed Aug 17, 2011 2:27 am
I was more thing mega drunken 'thiisssh is a breeeelllient idea maaaaate, knowssh hhhte besstest way of getting out voths dents' kinda tech :lol:
Post Posted: Wed Aug 17, 2011 2:53 am
I heard it somewhere... but it works... i turned a totally stuffed tank into tank that could hold more than 40L. Once you fix your tank, get a bash guard for sure... There's only so many times you can pop the dents out before you wreck the tank.
Post Posted: Wed Aug 17, 2011 3:34 am
I do have a tank guard... But I broke it :roll: Will be going back on once dents are removed. :)
Post Posted: Wed Aug 17, 2011 8:04 am
leave the dent and buy a Jerry can and holder ! lol
Users browsing this forum: No registered users and 111 guests
