| Author |
Message |
zukmeista
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
 Posted: Tue Aug 16, 2011 5:14 am |
I have heard you can remove dents from fuel tanks using compressed air but I am not sure how? Could someone enlighten me as to how it is done?
FullyZooked
Joined: Mon Oct 25, 2010 9:01 am Posts: 1009 Location: Bendigo
 Posted: Tue Aug 16, 2011 5:29 am |
Easy, remove fuel cap and fuel filter. Make sure the tank is empty first by pressurizing the tank through the inlet and catching fuel underneath by a fuel safe container.
Once the tank is empty, block the fuel outlet with a screw and a hoseclamp.
Now pressurize the tank with your compressor until you start hearing donk, donk! Dents are popped out and life is good.
I used a blower nozzle on my compressor and wrapped the head in a rag to seal when in the fuel inlet. I used a rag to eliminate the chance of over pressurizing the tank and doing damage.
_________________ Built Suzuki's shall reign Victorious.
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Tue Aug 16, 2011 7:10 am |
FullyZooked wrote: Easy, remove fuel cap and fuel filter. Make sure the tank is empty first by pressurizing the tank through the inlet and catching fuel underneath by a fuel safe container. Once the tank is empty, block the fuel outlet with a screw and a hoseclamp. Now pressurize the tank with your compressor until you start hearing donk, donk! Dents are popped out and life is good.
X2
but be carefull its easy to over pressurise the tank and blow the seams.
I'd use a regulator and just keep upping it slowly so you dont endup trying to blow it out at 120 psi
zukmeista
 Posted: Tue Aug 16, 2011 8:47 am |
How much pressure will it take to pop the dents out roughly? And can I do it with the same compressor I use for pumping up tyres after wheeling?
ajsr
 Posted: Tue Aug 16, 2011 8:58 am |
zukmeista wrote: How much pressure will it take to pop the dents out roughly? And can I do it with the same compressor I use for pumping up tyres after wheeling?
yes you can if you can seal it well enough.
30 psi should be shit loads for most dents, I bet most will pop at less than 20 psi
zukmeista
 Posted: Tue Aug 16, 2011 9:49 am |
Ok, hopefully it doesn't explode
FullyZooked
 Posted: Tue Aug 16, 2011 12:25 pm |
Use patience and a steady trigger finger if a regulator is not fitted.
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Tue Aug 16, 2011 12:48 pm |
X2 be very light on the trigger. Didnt take much air to crack the bottom of my tank
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
rpmwrx
Joined: Sat Jul 19, 2008 11:30 pm Posts: 1303 Location: Geelong
 Posted: Tue Aug 16, 2011 9:46 pm |
I filled my tank with water, then pressurised the tank with air. Worked really well...
bohuler
Joined: Wed Nov 10, 2010 9:18 am Posts: 1376 Location: Avonsleigh, Victoria
 Posted: Tue Aug 16, 2011 9:50 pm |
Couldn't you pop the dints out the same way you set the bead on a tire, a bit of start ya bastard and matches
p.s, can we grab a video if you decide to try this method!
_________________ Life's short, fiddle with your willy while you can
Teracis
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
 Posted: Tue Aug 16, 2011 10:10 pm |
bohuler wrote: Couldn't you pop the dints out the same way you set the bead on a tire, a bit of start ya bastard and matches p.s, can we grab a video if you decide to try this method!
If we're still talking about a fuel tank, he probably won't even need the start ya bastard!
Don't do it that way though, it would end in tears!
zukmeista
 Posted: Wed Aug 17, 2011 12:56 am |
You would have to be fuckin dumb to even consider that idea
atari4x4
 Posted: Wed Aug 17, 2011 1:21 am |
awesome tech VW Dave?
zukmeista
 Posted: Wed Aug 17, 2011 2:05 am |
What's the idea of putting water in it?
atari4x4
 Posted: Wed Aug 17, 2011 2:14 am |
i guess it's less volume to fill with air
BlueSuzy
 Posted: Wed Aug 17, 2011 2:24 am |
Less air, More weight on the dents.
Just air would do the same. I should try it gradually on the coily tank i have here
If it blows up it blows up, Dont really care, been sitting here for years
bohuler
 Posted: Wed Aug 17, 2011 2:27 am |
atari4x4 wrote: bohuler wrote: Couldn't you pop the dints out the same way you set the bead on a tire, a bit of start ya bastard and matches p.s, can we grab a video if you decide to try this method! awesome tech VW Dave?
I was more thing mega drunken 'thiisssh is a breeeelllient idea maaaaate, knowssh hhhte besstest way of getting out voths dents' kinda tech
rpmwrx
 Posted: Wed Aug 17, 2011 2:53 am |
zukmeista wrote: What's the idea of putting water in it?
I heard it somewhere... but it works... i turned a totally stuffed tank into tank that could hold more than 40L. Once you fix your tank, get a bash guard for sure... There's only so many times you can pop the dents out before you wreck the tank.
zukmeista
 Posted: Wed Aug 17, 2011 3:34 am |
I do have a tank guard... But I broke it  Will be going back on once dents are removed.
tobeszook
Joined: Sun Sep 26, 2010 7:38 am Posts: 453 Location: Drysdale Vic
 Posted: Wed Aug 17, 2011 8:04 am |
leave the dent and buy a Jerry can and holder ! lol
