It is currently Sun Nov 08, 2026 12:51 pm
Post Posted: Mon Jun 06, 2011 7:16 pm
There is ment to be a circlip on the end of the cv inside of your free wheeling hub right?
My cromos arnt sticking out at all for the clip to go on
Should I pull then out till I get a circlip on them, then push the axel back in untill it comes to rest on the circlip
Post Posted: Mon Jun 06, 2011 7:24 pm
Yeah, on normal ones there was a thread in the end that I screwed a bolt into so I could pull it out.
My Maruti build, Click WWW
Vehicle: 75 Cruiser
Post Posted: Mon Jun 06, 2011 7:25 pm
Can you pull the axle out just enough to get the clip on? If so, do that :D
Post Posted: Mon Jun 06, 2011 8:38 pm
I hope there's a thread on the end
I don't want to undo every thing after I rebuilt the bloody thing
Yea Steve I can pull it out a bit
Post Posted: Mon Jun 06, 2011 8:49 pm
x2 use one of the hub bolts on the end of the cv shaft. they fit perfect.
255 characters
Post Posted: Mon Jun 06, 2011 11:09 pm
As long as there will be enough spline inside the locker after I pull the axle out to get the circlip on I'll be happy
Thanks guys
Post Posted: Mon Jun 06, 2011 11:39 pm
Thanks guys
it should only come out about 5mm, anymore than that and you might have another issue?
255 characters
Post Posted: Tue Jun 07, 2011 12:35 am
The axle spline is about 2 or 3mm inside the hub spline
So it'll be more the 5mm to get the circlip on
Post Posted: Tue Jun 07, 2011 2:15 am
Have you done up the hub tight (leaving one hub bolt off of course? should not be more than 5-6 mll clearance, should just be enough to get the circlip over the notch in the spline. Perhaps you have too much silastic in between the surfaces?
255 characters
Post Posted: Tue Jun 07, 2011 2:42 am
No gasket glue just a paper gasket
It will be around 5mm to get the circlip on I reckon
Post Posted: Tue Jun 07, 2011 3:07 am
perfect cause the circlip is usually just in front of the face of the inner hub spline... only about 1mm movment. So if it is set right you should see the notch and perhaps another 1mm of spline. Good luck.
255 characters
Post Posted: Tue Jun 07, 2011 4:55 am
Sweet thanks mate
Post Posted: Tue Jun 07, 2011 1:45 pm
Turn the whole hub and brake assembly from steering lock to steering lock. The centre of the CV joint is supposed to be on the centreline of the Kingpin axis (Make sense of that?) By turning the hub assy, you will self-centre the CV on the Kingpin axis and push the outer axle out.
As others have said, there should be a thread in the end of the axle shaft to thread an M8 bolt in to pull the shaft out and hold it while fitting the circlip.
Post Posted: Tue Jun 07, 2011 3:29 pm
Cheers hutch I'll try that
Post Posted: Sat Dec 31, 2011 8:45 am
I'm having a similar issue. :?
I've tried jiggling the axle while pulling and turning the hub with no luck.
Looks like I need another 3mm.
Everything has been torqued up as per FSM. I'm thinking that the rear seal in the hub may not be tapped in far enough.
Any other suggestions?
SS
Post Posted: Sun Jan 01, 2012 5:45 am
I had heaps of trouble with one cv,
problem was mud hard packed around the rubber boot area,
once cleaned out had plenty of room for the circlip.
I realise a Vit is different set up, but still an area to look at
Post Posted: Sun Jan 01, 2012 6:15 am
Is the rear bearing seated properly? Did you replace bearing races? It might be the seal as you suggest
Post Posted: Sun Jan 01, 2012 6:40 am
:oops:
The cause ended up being me pressing the rear seal in to far, causing the rubber on the seal sitting between the bearing and where the bearing sits on the stub axle.
All good now. :P
SS
Post Posted: Sun Jan 01, 2012 6:56 am
That seal should just sit flush with the top of the hub
Post Posted: Sun Jan 01, 2012 7:15 am
:roll: I know that now. :oops:
SS
Post Posted: Sun Jan 01, 2012 7:16 am
:lol: :lol: pompoms
Post Posted: Sun Jan 01, 2012 11:50 am
Scrawn wrote:
:lol: :lol: pompoms
live & learn, so tomorrow we can forget it all.... :lol:
Users browsing this forum: No registered users and 57 guests
