It is currently Sun Nov 08, 2026 8:13 am
Vehicle: 02 GV SQ625 + 84 Sierra SJ410
Post Posted: Mon Dec 26, 2011 8:09 pm
Do decent extractors on a 1.0L improve performance?
I've got a hole in my exhaust and its starting to backfire when under engine/compression breaking...
Has anyone fitted a set of extracts to their 1.0L and noticed a performance gain or found it worthwhile? If so, what brand (or ebay seller) did you use?
Are exhausts pretty generic in that I can goto any exhaust place and ask them to chuck another on for me?
Post Posted: Mon Dec 26, 2011 8:22 pm
the gain is marginal when compared with putting a full 2" exhaust system on your car. if u put a set of extractors on after fitting a 2" system then u wont notice any difference other than the sound
Post Posted: Mon Dec 26, 2011 8:31 pm
well sound i want to keep to a minimum... it wont be for sounds, only performance.
alrighty so for the new exhaust a 2" system is worth looking into. cheers rocky.
Post Posted: Mon Dec 26, 2011 8:36 pm
2" is a little big for a 1 litre isn't it?
Post Posted: Mon Dec 26, 2011 8:43 pm
I'd suggest 1 & 3/4" maximum. I barely noticed much gain when I added mine to my 1.3. Might be easier to find extractors than a manifold tho
Post Posted: Mon Dec 26, 2011 8:48 pm
Thanks Damo/Scrawn
Post Posted: Mon Dec 26, 2011 8:53 pm
2" was has been fine for me on all my 1ltrs, your not going to loose pwr
Post Posted: Mon Dec 26, 2011 11:00 pm
IMO 2" is too big for 1L. Go for 1.75" and a good multi chambered muffler.
Post Posted: Mon Dec 26, 2011 11:33 pm
and what happens if u go to 2"
Post Posted: Mon Dec 26, 2011 11:41 pm
Mine droned like a mofo.
Post Posted: Tue Dec 27, 2011 1:49 am
I have a set of 1 litre extractors here - $50
Post Posted: Tue Dec 27, 2011 2:01 am
Like a Flowmaster?
Vehicle: Jeep
Post Posted: Tue Dec 27, 2011 6:16 am
Even though some say there is marginal improvement, usually 2 to 5%, you can notice the difference at higher RPM's... i have had a sports system fitted to every zook i have owned, its a good mod, and i felt a difference on every Zook !
Extractors work well with a sports system...
The idea for a sports system, is to have as little restriction as possible, but to do this, it usually comes with noise... and having no noise, means adding restriction, which defeats the purpose... getting a hi-flo cat removes ALOT of restriction, i would aim for a medium noise muffler, that way you get a bit less restiction with a bit of noise... :wink: :lol:
Post Posted: Tue Dec 27, 2011 6:51 am
The problem is that 2-5% is within the margin of error of a dyno and undetectable from the driver's seat. It is generally accepted that changes in HP of less than 10% can't reliably be felt from the driver's seat....
However, a loud car always feels faster than a quiet car.
I'm sure extractors help, but in all honesty, I don't think I'd be spending money on an F10. Extractors and a well built exhaust is probably going to cost 1/2 the conversion price to a G13.
Post Posted: Tue Dec 27, 2011 8:55 am
Like a Flowmaster?
Dunno. :roll:
Post Posted: Tue Dec 27, 2011 10:34 am
Bingo!!! :P
Post Posted: Tue Dec 27, 2011 9:59 pm
Hi all, just put extractors and a 1 3/4 exhaust on my 96 coily.has 190k on the clock. revs a lot easier and has notocable power upgrade ,,not a lot ,but enough to make me smile.Getting between 8.5-9 litres per 100k,s .Kept the existing cat converter.. worth doing I think
Users browsing this forum: No registered users and 117 guests
