It is currently Thu Aug 06, 2026 2:37 am
Post Posted: Thu Dec 01, 2011 5:41 am
Hey guys and girls...
So my problem is just this...
Put the new front diff in yadda yadda yadda... No problems there
Then *insert dramatic music here* came the test drive...
Placed in 4wd high go for a spin down the block. under
Acceleration front end lifts up and the back end Boggs down
The only thing I can think of is that the diff ratio is wrong...
But... I am sure the wrecker counted the teeth right not only
In front of me but imam sure As hell I counted them right...
8 teeth on pinion 41 on the crown... Any ideas???
Stocker
Post Posted: Thu Dec 01, 2011 6:23 am
jack the back up & check the rear diff ratio... maybe you don't have 512's. 8O
did you check the one that came out?
Post Posted: Thu Dec 01, 2011 7:06 am
& don't select 4wd till you have the same ratio front & back again.....
Post Posted: Thu Dec 01, 2011 7:23 am
Shit bugger bitch bum... Just counted the output of the cv's vs drive shaft... By the look of it now I have roughly a 4.9 ratio... Will call the wrecker 2morro but I'm not holding my breath... Does anyone have another 5.125 center with 26 spline axles???
Stocker
Post Posted: Wed Dec 14, 2011 8:25 am
Sorry to Rehatch Old Egg's guys, but i still need a 26 Spline 5.125 Front Diff Center to get my zookie going...
Stocker
Post Posted: Wed Dec 14, 2011 8:28 am
what about the one from the wreck you bought & just run a 22 spline RHS CV?
Post Posted: Wed Dec 14, 2011 8:29 am
isn't the 26Spline Much stronger? I am running 31's now...
Stocker
Post Posted: Wed Dec 14, 2011 8:39 am
i ran a 22 spline inner for a year or more on 31's before building up the steel diff with the RD88 (26spline) locker, never broke it but i'm not a throttle jockey. :wink:
Post Posted: Wed Dec 14, 2011 8:40 am
hahaha... well since i whacked the 31's under mine, i haven't been anywhere near as rough on mine.... i will change the 22spine one into mine then :)
Stocker
Post Posted: Tue Dec 27, 2011 10:38 pm
Ok so the finger got pulled out of my butt
And I ripped the front diff out to find that it is the right ratio diff 41 teeth on the crown wheel an 8 teeth on the pinion...
So to keep you all up to date on what's been done...
I fixed the manual locking hub. Replaced the diff. And now the drive line loads up in 4wd.
...help
Stocker
Post Posted: Wed Dec 28, 2011 2:38 am
Bump!!!
Stocker
Post Posted: Wed Dec 28, 2011 2:40 am
Just pulled the rear it is also a 5.125 taro with 41 teeth on the crown and 8 on the pinion
Stocker
Post Posted: Wed Dec 28, 2011 2:48 am
did ya do a timbo and put the front diff in upside down?
Post Posted: Wed Dec 28, 2011 3:43 am
what ratio was the one you broke?
EDIT: just saw that you've pulled the rear diff to find it was also 512:1
are you running the same size tyres front & back? :?
Post Posted: Wed Dec 28, 2011 3:46 am
That was my next guess, different tyre size?
Post Posted: Wed Dec 28, 2011 8:48 pm
Hey guys you physically cant put the front diff upside down due to the mount on the pinion.
Definitely got the same size tyres front and back 31x11.5r15
Stocker
Post Posted: Thu Dec 29, 2011 12:56 am
Was just thinking it might be binding up between 4wd hi & low...
Has anyone had this problem with the vitara transfer case???
Stocker
Users browsing this forum: No registered users and 936 guests
