It is currently Sun Nov 08, 2026 11:52 am
Post Posted: Wed Nov 16, 2011 7:15 am
:helloo:
I'm getting my new zook on Saturday and just wondering what the diff ratio is for my GV? I have done a net search and can't seem to find it. Maybe I need to learn how to search properly :D
Dave
Post Posted: Wed Nov 16, 2011 7:17 am
slaughto or emanuel
Post Posted: Wed Nov 16, 2011 7:31 am
emanuel :D
Wont they be 4.6 for auto and 4.8 manual??
Post Posted: Wed Nov 16, 2011 7:33 am
No idea rob. i want to do the vitara upgrade with free wheeling hubs and jas thought they were 5.2's but i couldnt find any info so i thought i'd just ask :D
Dave
Post Posted: Wed Nov 16, 2011 7:34 am
did a bit of a search and i found this....
early 1.6swb GV's had 5.12
2.0l man gv = 4.8
2.0l auto GV = 5.12
2.5 V6 man = 4.3
2.5 V6 auto = 4.8.
You can use the vitara / X90 10bolt diffs in the front and 12bolt in the rear
Vitara ratios are 4.6, 4.8 and 5.12
Sierra lockrights can be used in either diff.
Air lockers are GV or Vitara.
Axles are 26 spline.
T/case gearing is available but only gives reduction in low range.
so if you want to go bigger tyres then find yourself some 5.12 diffs.
I have 5.12 front and rear. Front still has the air engagement.
You GV should have 4.8 diffs
Vehicle: Suzuki
Post Posted: Sat Dec 31, 2011 10:49 am
I'm looking at 5.12 gears for my GV. Were they are straight swap B4T?
Post Posted: Sat Dec 31, 2011 10:57 am
you'll need to have the front 5.12 built into your steel housing, rear should bolt in.
Vehicle: Suzuki
Post Posted: Sat Dec 31, 2011 11:07 am
I have the aluminium housing... is that going to screw me?
Post Posted: Sun Jan 01, 2012 7:53 am
No .
the alloy housing is the same as the steel one but just not as strong.
Vehicle: Suzuki
Post Posted: Sun Jan 01, 2012 10:20 am
No worries, think I may have a steel housing if it is so. Shep is checkin out a local gv wreck this week. :)
Users browsing this forum: Google [Bot] and 64 guests
