It is currently Sun Nov 08, 2026 12:55 pm
Post Posted: Sat Dec 31, 2011 9:29 am
:helloo: guys,
I'm not sure how it happened but i went to start my car today and it wouldn't start. Spent a few hour's looking around the engine bay looking for a loose/broken wire or blown fuse. After a bit more looking i seen that some how the main winch power cable had been crushed and was arcing out on the body (hence the car not starting). So after i disconnected that, i hooked some jumper leads on to the car hey presto it started.....then it stalled...tried jump starting it again....stalled again.
Any way after a few revs it would idle with-out stalling....problem solved....no wrong it died again once i tried to turn my head lights on. So i hooked the volt meter on whilst running and i was getting 14.4 volt's at the battery while idling. So i then turned the car off to see how many volt's the battery had after running the car for 10mins....5 volt's :?. I then thought it maybe the alternator, so i jump started the car again, once running i disconnected the battery and the car continued to run, so it can't be the alternator right?
So what do i need to look for now to figure out while the battery isn't getting charge?
Can i safely rule out it's NOT alternator?
Where to start? :(
Cheers,
Andrew
Post Posted: Sat Dec 31, 2011 9:37 am
not enough limiter lol
dodgy brothers mechanical
Post Posted: Sat Dec 31, 2011 10:48 am
dude your batt is shagged either way. get a newwy and report back. Dont connect your winch yet. Your elecs are fine if you managed to get it going so dont stress about that.
MY BUILD THREAD HERE!!!!!
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat Dec 31, 2011 11:40 am
a nice fat 8 gauge winch cable would give your battery a good fryin. 5 volts after 10 minutes with no draw means you have dead cells, it should at least have 10.5V. be careful taking it out, ive seen these things cook so bad that when they've been lifted they've cracked stripping the paint off the engine bay.
i think i might put isolation on my winch power because of whats happened here!
Post Posted: Sat Dec 31, 2011 12:09 pm
Thanks guys! I will get another battery tomorrow under warranty hopefully. :D
Post Posted: Sat Dec 31, 2011 1:44 pm
rap your main cable in convolute best way to solve the problem and looks pretty neat also
Vehicle: Jeep
Post Posted: Sat Dec 31, 2011 3:05 pm
Yep, what the others have said, you have fried your battery... you are very lucky the Jims have a small battery... if it had been a big one, with more amps/CCA behind it, you may have had some chared black remains left... is there is a fuseable link/circuit breaker/isolator switch, on your winch power cable, sounds like its straight from the battery... :roll: :?
Post Posted: Sat Dec 31, 2011 4:53 pm
so this would explain why it was doing weird things at the powerlines then huh? =) lucky it didnt fry the battery out there and do all this weird crap!
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat Dec 31, 2011 6:51 pm
hay on second thought for only $11 US mabie a RFFA500 might be worth it, its a 2 pack of 500 amp fuses. they take 10 seconds to blow, but that's better then melting insulation of ya heavy copper. their a rockford fosgate fuse so they should be pretty good. just not sure how a ceramic fuse would handle vibration...
Post Posted: Sat Dec 31, 2011 7:53 pm
FFS put some effort into running your cable properly, you realise you just missed your car burning to the ground dont you?
Post Posted: Sat Dec 31, 2011 9:54 pm
Or the battery BLOWING the bonnet off.....
Post Posted: Sat Dec 31, 2011 10:47 pm
how did the cable get crushed in the 1st place may i ask? wanna make sure my winch isnt routed the same way.
i dont know anyone who fuses their winches, i havent even got my redarc fused like they say.
calculated risk.
Post Posted: Sat Dec 31, 2011 10:55 pm
calculated risk.
I had all the winch cables together so they couldn't move but from the trip to Mundaring the other night, all the vibrations had caused one of the cables to move. Then some stage during the trip i must of hit my bar on something and the cable was jammed between bar & the body crushing the cable. NFI idea how the bar moved tho, i can't remember hitting any thing that hard :? .
I don't think you will have the problem of the ARB moving...shitty xrox bar :x maybe it's time to change bar's :P
Vehicle: 07 vvt jimny
Post Posted: Sun Jan 01, 2012 12:04 am
yess im glad i got and arb wnch bar for the jimny, ha ha ha ah ha anyways.... back to my problem corner :(
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Sun Jan 01, 2012 12:09 am
climbing up that rut near the middle mud hole when you were smashing the rear control arm mount.... when you reversed down you hit the bar on the passengers side wing bit pretty dam hard =)
Post Posted: Sun Jan 01, 2012 12:12 am
I do shit like that & not think it's a hard hit from the driver's seat.... :roll:
Easy to do.
Post Posted: Sun Jan 01, 2012 12:13 am
Easy to do.
But you got a good bar stekky :helloo:
Post Posted: Sun Jan 01, 2012 12:14 am
:lol: :lol: :lol: Goon one........ it's bent again..... :lol: :lol: :lol:
Post Posted: Sun Jan 01, 2012 12:15 am
:blink: :D
Post Posted: Sun Jan 01, 2012 12:16 am
:roll: Tree in my way....... :roll:
Post Posted: Sun Jan 01, 2012 1:27 am
All fixed :P thanks guys! Turns out the battery was fruked :?
Now i'm of wheeling to see what i can break next :? :( :P :roll: :lol:
Post Posted: Sun Jan 01, 2012 1:30 am
Isn't that what everyone said? :roll:
Post Posted: Sun Jan 01, 2012 1:50 am
Yes...but the battery was only 3months old hence the " :? "
Post Posted: Sun Jan 01, 2012 1:53 am
The battery you say?
8O Im shocked......
ok not that shocked. glad its fixed and hope you learnt a bit in the process.
Post Posted: Sun Jan 01, 2012 2:04 am
That's what happens when you create a dead short
Post Posted: Sun Jan 01, 2012 2:50 am
Scrawn wrote:
That's what happens when you create a dead shit
:helloo:
Post Posted: Sun Jan 01, 2012 2:56 am
the ol dead shit aye :helloo:
sorry CHOP :P
Post Posted: Sun Jan 01, 2012 3:03 am
Much better than live shit :helloo:
Post Posted: Sun Jan 01, 2012 3:06 am
WTF are you guy's going on about? :roll:
Vehicle: Jeep
Post Posted: Sun Jan 01, 2012 3:11 am
X 2
I dont think he does realise that... :roll:
Users browsing this forum: Google [Bot] and 71 guests
