It is currently Wed Nov 11, 2026 10:24 am
Vehicle: A shed full of pieces so far
Post Posted: Tue Mar 20, 2012 4:50 pm
Just wondering if anyone knows if there's any reason I couldn't cut the coil mounts of the diffs out of a 97 Sierra and weld on spring perches to suit my old nt.
Post Posted: Tue Mar 20, 2012 5:04 pm
Sure you could.... but that would open up a whole new can of worms -
Coil sierras are wider track than leaf, so rear axles and inner front axles are unique.
The front diff is unique
The tie rod is behind the axle and is likely to foul the leaf springs.
I have been led to believe that the knuckles can't be swapped between the coil and leaf axles, but I don't know this for sure.
This is important because if you want to swap to a conventional sierra front diff (so, for instance, you can have some choice of diff ratio) then the tie rod will foul the diff.
There are no upgraded parts for coil diffs.
All up, a set of coil sierra axles would be the worst possible choice for swapping into a NT sierra.
If you were really looking for a whacky swap, Jimny diffs would be superior - at least there are upgraded parts (and better diff gears) available for Jimny diffs.
Post Posted: Tue Mar 20, 2012 5:06 pm
Thanks for that. Exactly what I needed to know. These are most likely the reasons why they are so cheap.
Post Posted: Tue Mar 20, 2012 5:32 pm
Correct Steve, swivel hubs are not interchangeable.
Haven't looked but I'm led to believe coily and jimny are same (hubs at least).
Post Posted: Tue Mar 20, 2012 5:43 pm
That would make sense..... if coily's made sense. :D
Steve
Post Posted: Tue Mar 20, 2012 6:56 pm
Coily run vitara hubs
Post Posted: Tue Mar 20, 2012 7:46 pm
Awesome!.... Or something!
Steve
(I did know this. I don't if it's good, bad or indifferent though. It does mean the rear diff centre and the hubs are the same as something else Suzuki made though :D)
Post Posted: Tue Mar 20, 2012 8:02 pm
:idea: :?: Do go on..
Post Posted: Wed Mar 21, 2012 8:03 am
I'm not sure if there exactly the same but we found out after alot of mucking round that my old one took vitara bearings and seals
Vehicle: 1985 lwb sierra UTE
Post Posted: Fri May 25, 2012 9:27 am
So does the jimmy run the same steering set up because iv heard of a bloke fitting jimmy diffs on wt
Green? greeeen is nice !
Post Posted: Fri May 25, 2012 9:35 am
Yes, its the same as a coily. And just as big of a time waste as fitting coily diffs to a leafy.
Its just ass backwards.
Post Posted: Fri May 25, 2012 9:57 am
ass backwards.
Is the new AWESOME!!! :peaceout:
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Fri May 25, 2012 11:02 am
JrZook wrote:
ass backwards.
Well I guess you'll be doing a coily diff swap then :roll:
:thefinger:
Vehicle: Coily.
Post Posted: Fri May 25, 2012 2:32 pm
Nooooo,the vibe of the thing would be wrong,just put the Coily Diffs on here for sale and i'm sure someone will buy them :oops:
Post Posted: Fri May 25, 2012 4:50 pm
Yer no one wants them I'm going wt diffs I'm just hoping some one comes up with sum
Post Posted: Sun May 27, 2012 12:02 pm
so with a 97 coily, if i were replacing the swivel hubs and wheel bearings, what would i buy? because they don't make them for coilys anymore..
Vehicle: chick magnet coily
Post Posted: Sun May 27, 2012 7:43 pm
i got a wt kit and it fit :peaceout:
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Sun May 27, 2012 9:04 pm
The swivel hubs seals/ felts and king pin bearings are the same as any other sierra.
I believe that SJ80's and vitara run the same wheel bearing hub, and if I had to make an educated guess, the wheel bearing will be the same....
Or you could buy this..... http://www.ebay.com.au/itm/Front-Wheel-Bearing-Kit-Suzuki-Sierra-SJ80-4wd-1996-99-/400216745113?pt=AU_Car_Parts_Accessories&hash=item5d2ec6e499
Post Posted: Sun May 27, 2012 9:06 pm
Can't have. The wheel bearings are completely different from WT to coily.
Post Posted: Mon May 28, 2012 4:21 am
i meant swivel hub kit :peaceout:
Users browsing this forum: No registered users and 139 guests
