| Author |
Message |
Mitchie.1
Joined: Fri Mar 09, 2012 7:54 pm Posts: 89 Location: Toowoomba
Vehicle: A shed full of pieces so far
 Posted: Tue Mar 20, 2012 4:50 pm |
Just wondering if anyone knows if there's any reason I couldn't cut the coil mounts of the diffs out of a 97 Sierra and weld on spring perches to suit my old nt.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Tue Mar 20, 2012 5:04 pm |
Sure you could.... but that would open up a whole new can of worms -
Coil sierras are wider track than leaf, so rear axles and inner front axles are unique.
The front diff is unique
The tie rod is behind the axle and is likely to foul the leaf springs.
I have been led to believe that the knuckles can't be swapped between the coil and leaf axles, but I don't know this for sure.
This is important because if you want to swap to a conventional sierra front diff (so, for instance, you can have some choice of diff ratio) then the tie rod will foul the diff.
There are no upgraded parts for coil diffs.
All up, a set of coil sierra axles would be the worst possible choice for swapping into a NT sierra.
If you were really looking for a whacky swap, Jimny diffs would be superior - at least there are upgraded parts (and better diff gears) available for Jimny diffs.
Mitchie.1
 Posted: Tue Mar 20, 2012 5:06 pm |
Thanks for that. Exactly what I needed to know. These are most likely the reasons why they are so cheap.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue Mar 20, 2012 5:32 pm |
Correct Steve, swivel hubs are not interchangeable. Haven't looked but I'm led to believe coily and jimny are same (hubs at least).
Gwagensteve
 Posted: Tue Mar 20, 2012 5:43 pm |
want33s wrote: Correct Steve, swivel hubs are not interchangeable. Haven't looked but I'm led to believe coily and jimny are same (hubs at least). That would make sense..... if coily's made sense.  Steve
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Tue Mar 20, 2012 6:56 pm |
Gwagensteve
 Posted: Tue Mar 20, 2012 7:46 pm |
Awesome!.... Or something! Steve (I did know this. I don't if it's good, bad or indifferent though. It does mean the rear diff centre and the hubs are the same as something else Suzuki made though  )
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Tue Mar 20, 2012 8:02 pm |
Gwagensteve wrote: It does mean the rear diff centre and the hubs are the same as something else Suzuki made though  )  Do go on..
_________________ mlm
got_bar_work
 Posted: Wed Mar 21, 2012 8:03 am |
I'm not sure if there exactly the same but we found out after alot of mucking round that my old one took vitara bearings and seals
KEENSY85
Joined: Wed May 09, 2012 12:46 am Posts: 1742 Location: north brisbane
Vehicle: 1985 lwb sierra UTE
 Posted: Fri May 25, 2012 9:27 am |
So does the jimmy run the same steering set up because iv heard of a bloke fitting jimmy diffs on wt
_________________ Green? greeeen is nice !
Fatzook
 Posted: Fri May 25, 2012 9:35 am |
KEENSY85 wrote: So does the jimmy run the same steering set up because iv heard of a bloke fitting jimmy diffs on wt Yes, its the same as a coily. And just as big of a time waste as fitting coily diffs to a leafy. Its just ass backwards.
JrZook
 Posted: Fri May 25, 2012 9:57 am |
Fatzook
 Posted: Fri May 25, 2012 11:02 am |
JrZook wrote: Fatzook wrote: ass backwards. Is the new AWESOME!!!  Well I guess you'll be doing a coily diff swap then
HarryHoudini
Joined: Fri Jul 01, 2011 12:34 am Posts: 360 Location: Northern NSW Australia.
Vehicle: Coily.
 Posted: Fri May 25, 2012 2:32 pm |
Mitchie.1 wrote: Just wondering if anyone knows if there's any reason I couldn't cut the coil mounts of the diffs out of a 97 Sierra and weld on spring perches to suit my old nt. Nooooo,the vibe of the thing would be wrong,just put the Coily Diffs on here for sale and i'm sure someone will buy them
_________________ Regards All from far Northern NSW.
KEENSY85
 Posted: Fri May 25, 2012 4:50 pm |
Yer no one wants them I'm going wt diffs I'm just hoping some one comes up with sum
bek
Joined: Thu Sep 10, 2009 11:30 pm Posts: 810 Location: Ipswich
 Posted: Sun May 27, 2012 12:02 pm |
so with a 97 coily, if i were replacing the swivel hubs and wheel bearings, what would i buy? because they don't make them for coilys anymore..
fully sick coily
Joined: Tue Feb 14, 2012 7:47 pm Posts: 474 Location: brisbane
Vehicle: chick magnet coily
 Posted: Sun May 27, 2012 7:43 pm |
bek wrote: so with a 97 coily, if i were replacing the swivel hubs and wheel bearings, what would i buy? because they don't make them for coilys anymore.. i got a wt kit and it fit
_________________ when in doubt... HOLD IT PINNED!!! :)
Fatzook
 Posted: Sun May 27, 2012 9:04 pm |
Fatzook
 Posted: Sun May 27, 2012 9:06 pm |
fully sick coily wrote: bek wrote: so with a 97 coily, if i were replacing the swivel hubs and wheel bearings, what would i buy? because they don't make them for coilys anymore.. i got a wt kit and it fit  Can't have. The wheel bearings are completely different from WT to coily.
fully sick coily
 Posted: Mon May 28, 2012 4:21 am |
Fatzook wrote: fully sick coily wrote: bek wrote: so with a 97 coily, if i were replacing the swivel hubs and wheel bearings, what would i buy? because they don't make them for coilys anymore.. i got a wt kit and it fit  Can't have. The wheel bearings are completely different from WT to coily. i meant swivel hub kit
