It is currently Thu Oct 29, 2026 12:28 pm
Vehicle: 96 tin top sierra 31's omes
Post Posted: Tue Jan 14, 2014 10:48 am
hey guys
i have allot of 12v accessories and am looking to neaten up my fire hazzard...
whats the best way to keep wiring neat?
Jake
Post Posted: Tue Jan 14, 2014 12:25 pm
I find that the most effective method is to close the bonnet and pretend that every thing is awesome under it
Post Posted: Tue Jan 14, 2014 12:46 pm
I thought you were going to say "with fire" :D
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Jan 14, 2014 1:45 pm
i used bus bar style power rails with screws tapped into them. did a positive and negative rail inside the cab. going to put a plastic cover over the positive eventually but at the moment its just live.
got them from a boat shop.
have a 100A fuse feeding them through a fat cable through the firewall. run a 400w amp, compressor, electronic break controller, and may one day run a fridge off it.
Vehicle: 89 Sierra Widetrack
Post Posted: Tue Jan 14, 2014 1:59 pm
Lots of black tape!
Depending on who has had your car there may be old wiring from lights ect you could cut away
Vehicle: Drover pickup turk
Post Posted: Tue Jan 14, 2014 2:48 pm
Split loom tubing and heatshrink!
I like the tuna here
Vehicle: '96 LWB trayback
Post Posted: Tue Jan 14, 2014 3:49 pm
Give it to an auto electrician with a fist full of money.
Post Posted: Tue Jan 14, 2014 4:08 pm
I work at an auto elec shop, it would cost too much.
Split tube and heat shrink ;-)
Vehicle: 2011 Jimny
Post Posted: Tue Jan 14, 2014 4:46 pm
As others have said, wrinkle dick (split tube) and heat shrink.
Plus this http://www.ebay.com.au/itm/FUSE-HOLDER-BOX-4-WAY-CARAVAN-4X4-DUAL-BATTERY-SYSTEM-12-VOLT-12V-NEW-/400607253473?pt=AU_Car_Parts_Accessories&hash=item5d460d93e1
Awesome idea, just one Power in and power out to everything and they are fused as well, i put one in the Jimny for UHF and my lightbar.
Post Posted: Wed Jan 15, 2014 1:34 pm
X2, out of sight out of mind, it works, woohoooo
Post Posted: Wed Jan 15, 2014 6:48 pm
Take some photos and outline what you want to do.
Generally messy wiring is also not very efficient and hiding it doesnt help.
Post Posted: Wed Jan 15, 2014 8:07 pm
This thread gets a genuine hardy laugh out of me ...
Vehicle: sj51
Post Posted: Wed Jan 15, 2014 8:10 pm
i started with sorting out a neatish mounting bracket for all my bits, then ran all the wires i needed and cut to length
then rip it all out and turned it into one big loom, taped, tubes soldered and then refitted
i tried to follow factory wiring were posible and tucked it under things when possible too
mine isnt the best job, but i think its far from the worst..
Post Posted: Wed Jan 15, 2014 8:32 pm
I think it is important to never trim cable ties as that draws people's eyes away from the truly dodgy stuff.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jan 15, 2014 9:12 pm
ill replace every cable tie before returning to QLD. sound advice shep thanks.
what kind of which controll box is that under the bonnet? in the engine bay?
seams lika a much better place to put one then where mine is I.E. full of water every time i go to use it
Vehicle: sj51
Post Posted: Thu Jan 16, 2014 3:04 pm
Just the standard warn one that came with my winch
Post Posted: Fri Jan 17, 2014 6:29 pm
I will get one tomorrow and try put it up
Thanks for the help guys
Probably wont go with yoyr suggestions shep, sorry :D good laugh though
Thanks jake
Vehicle: 91' Sierra GTI
Post Posted: Thu Feb 20, 2014 1:45 pm
if you are talking about aftermarket wiring, I ran a huge cable from the AUX BATT to a separate fusebox inside the cab up the passenger side firewall. I then made a board with solenoids (push on style for easy replacement) and even small sub fuse boxes for ON, ACC, LIGHTS. Then you can crimp on the connectors and plug them where they are supposed to go. Simple and easy to understand when you need to comeback later to troubleshoot or add something new.
I only bother to shrink wrap joins,l the rest is tape, tape and more tape. Wide duct tape is great for less turns.
Vehicle: WR250F/Jeep XJ
Post Posted: Sat Feb 22, 2014 7:08 am
The fuse box out of early vitaras are great for an accessory setup as they use the big squarish blade fuses that go up to 80odd amps. So you can run basically any accessory off them. I used one in my zook for running stuff like my big compressor and rear mounted thermo fans. Got it from a wrecker with a bunch of good battery cable and a handful of assorted fuses from a few vehicles for around 10 bucks. It has about five ports from memory.
it'll allow you to remove everything off your battery to a better location like the passenger wheel arch or like above, inside the passenger firewall behind the dash.
Post Posted: Mon Feb 24, 2014 5:39 am
Likewise EL/EF falcon. I grab the engine fuse box when I grab an alternator.
Users browsing this forum: No registered users and 372 guests
