| Author |
Message |
Perram
Joined: Fri Feb 24, 2012 6:55 pm Posts: 502 Location: sydney
Vehicle: 96 tin top sierra 31's omes
 Posted: Tue Jan 14, 2014 10:48 am |
hey guys
i have allot of 12v accessories and am looking to neaten up my fire hazzard...
whats the best way to keep wiring neat? Jake
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Tue Jan 14, 2014 12:25 pm |
I find that the most effective method is to close the bonnet and pretend that every thing is awesome under it
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13014 Location: Melbourne
 Posted: Tue Jan 14, 2014 12:46 pm |
I thought you were going to say "with fire"  Steve.
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Tue Jan 14, 2014 1:45 pm |
i used bus bar style power rails with screws tapped into them. did a positive and negative rail inside the cab. going to put a plastic cover over the positive eventually but at the moment its just live. got them from a boat shop. have a 100A fuse feeding them through a fat cable through the firewall. run a 400w amp, compressor, electronic break controller, and may one day run a fridge off it.
azzas15
Vehicle: 89 Sierra Widetrack
 Posted: Tue Jan 14, 2014 1:59 pm |
Lots of black tape!
Depending on who has had your car there may be old wiring from lights ect you could cut away
Blkfxx
Joined: Sat Feb 04, 2012 7:11 pm Posts: 1105 Location: Oberon, NSW
Vehicle: Drover pickup turk
 Posted: Tue Jan 14, 2014 2:48 pm |
Split loom tubing and heatshrink!
_________________ Quote: I like the tuna here
mnemonix
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1409 Location: Newcastle NSW
Vehicle: '96 LWB trayback
 Posted: Tue Jan 14, 2014 3:49 pm |
Give it to an auto electrician with a fist full of money.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Tue Jan 14, 2014 4:08 pm |
I work at an auto elec shop, it would cost too much. Split tube and heat shrink
Skippy
Joined: Sat Apr 14, 2012 9:57 am Posts: 531 Location: Gold Coast
Vehicle: 2011 Jimny
 Posted: Tue Jan 14, 2014 4:46 pm |
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Wed Jan 15, 2014 1:34 pm |
shep wrote: I find that the most effective method is to close the bonnet and pretend that every thing is awesome under it X2, out of sight out of mind, it works, woohoooo
royce
 Posted: Wed Jan 15, 2014 6:48 pm |
Take some photos and outline what you want to do. Generally messy wiring is also not very efficient and hiding it doesnt help.
losfer
 Posted: Wed Jan 15, 2014 8:07 pm |
This thread gets a genuine hardy laugh out of me ...
pezz
Joined: Fri May 15, 2009 11:30 pm Posts: 2108 Location: western vic
Vehicle: sj51
 Posted: Wed Jan 15, 2014 8:10 pm |
i started with sorting out a neatish mounting bracket for all my bits, then ran all the wires i needed and cut to length then rip it all out and turned it into one big loom, taped, tubes soldered and then refitted i tried to follow factory wiring were posible and tucked it under things when possible too mine isnt the best job, but i think its far from the worst..
shep
 Posted: Wed Jan 15, 2014 8:32 pm |
I think it is important to never trim cable ties as that draws people's eyes away from the truly dodgy stuff.
Jezza86
Platinum Supporter
Vehicle: 2010 jimny
 Posted: Wed Jan 15, 2014 9:12 pm |
shep wrote: I think it is important to never trim cable ties as that draws people's eyes away from the truly dodgy stuff. ill replace every cable tie before returning to QLD. sound advice shep thanks. what kind of which controll box is that under the bonnet? in the engine bay? seams lika a much better place to put one then where mine is I.E. full of water every time i go to use it
pezz
Vehicle: sj51
 Posted: Thu Jan 16, 2014 3:04 pm |
Just the standard warn one that came with my winch
Perram
 Posted: Fri Jan 17, 2014 6:29 pm |
I will get one tomorrow and try put it up Thanks for the help guys Probably wont go with yoyr suggestions shep, sorry  good laugh though Thanks jake
Zookrider
Vehicle: 91' Sierra GTI
 Posted: Thu Feb 20, 2014 1:45 pm |
if you are talking about aftermarket wiring, I ran a huge cable from the AUX BATT to a separate fusebox inside the cab up the passenger side firewall. I then made a board with solenoids (push on style for easy replacement) and even small sub fuse boxes for ON, ACC, LIGHTS. Then you can crimp on the connectors and plug them where they are supposed to go. Simple and easy to understand when you need to comeback later to troubleshoot or add something new.
I only bother to shrink wrap joins,l the rest is tape, tape and more tape. Wide duct tape is great for less turns.
dank
Joined: Sat Apr 05, 2008 10:30 pm Posts: 1157 Location: VIC
Vehicle: WR250F/Jeep XJ
 Posted: Sat Feb 22, 2014 7:08 am |
The fuse box out of early vitaras are great for an accessory setup as they use the big squarish blade fuses that go up to 80odd amps. So you can run basically any accessory off them. I used one in my zook for running stuff like my big compressor and rear mounted thermo fans. Got it from a wrecker with a bunch of good battery cable and a handful of assorted fuses from a few vehicles for around 10 bucks. It has about five ports from memory.
it'll allow you to remove everything off your battery to a better location like the passenger wheel arch or like above, inside the passenger firewall behind the dash.
Gwagensteve
 Posted: Mon Feb 24, 2014 5:39 am |
Likewise EL/EF falcon. I grab the engine fuse box when I grab an alternator.
