It is currently Wed Oct 28, 2026 7:44 am
Post Posted: Thu Nov 26, 2009 3:52 am
car idle fluxulates when hot and idling high wont idle down. anyone with ideas please.
Post Posted: Thu Nov 26, 2009 4:12 am
That very interesting Mine does opposite. It has a slight miss when it's cold , have had it hooked up to all sorts of crapp at mechanics , He recons it's all fine But admitts it sound rough, But when it warms up ? All gone !! :?
I Like cat's they make good hats !
Post Posted: Thu Nov 26, 2009 4:34 am
hi, i had simular probs with mine.
the mechanic found a crack in the intake manifold, so i got that replaced a long with another throttle body. fixed the prob.
hope that helps somehow.
Mitch
Post Posted: Thu Nov 26, 2009 5:49 am
I had a similar problem
http://www.auszookers.com/index.php?nam ... pic&t=4222
Turned out to be the pipe that runs from the IAC valve to the thermo housing was full of crud.
Vehicle: '96 LWB trayback
Post Posted: Thu Nov 26, 2009 6:11 am
Have you checked for vacuum leaks?
Vehicle: Jeep
Post Posted: Thu Nov 26, 2009 6:23 am
Oops my bad, just saw it is an EFI motor, lol...
Post Posted: Thu Nov 26, 2009 12:27 pm
yep check for vacuum leaks on every hose, mine was a small leak in a few hoses all compounding into enough to cause trouble
clean your airflow meter with some contact clean too
Post Posted: Thu Nov 26, 2009 2:27 pm
high idle will be caused by many things, e.g. faulty temp sensor, faulty throttle position sensor, both of these will cause a check engine light though.
There is a coolant hose going through the bottom of the intake manifold, inside there is a motor that spins and either allows water through or blocks it, i believe this is to heat the air that passes through the throttle body, if this is rusted shut then it will cause your exact symptoms.
Post Posted: Fri Nov 27, 2009 12:25 am
no there is 2 seperate sections there
there s the IAC which is a valve that the ecu uses to bleed air around the throttle body to up the idle spedd when the ac is on or the lights or whatever
there there is a waxstat thingo that when cold does the same thing, the coolant heats it up and it blocks off the extra air, same thing as a sierra auto choke almost
Post Posted: Sun Nov 29, 2009 1:46 am
thanks for the help guys just took it back to the mechanics they can deal with it cheers kermet
89 suzi... 5" calmini suspension... 2.5" body lift
Post Posted: Fri Jul 09, 2010 2:41 am
hey kermit, did you find the problem. my sons is driving me nuts. one minute it works properly next minute it mucks up. some how its connected to a/c as well ahhhhhhhhhhhhhhhhhhh
Users browsing this forum: No registered users and 315 guests
