It is currently Thu Nov 05, 2026 3:40 pm
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3
Post Posted: Tue Jul 21, 2009 2:33 am
Here's a good one for GV owners. After a recent day trip (http://auszookers.com/index.php?name=Fo ... ic&t=5491I) the lack of decent approach angle became rather evident - a fair bit of paint got exchanged for dirt!
I am trying to chase up a bullbar to cure this issue. But this certainly would not get posted in this thread (big $$$ for a GV bar). So I got to thinking - why not just cut away the plastic bits that aren't needed?
Cost? $0! Gain? At least a handful of degrees approach angle :D
Post Posted: Tue Jul 21, 2009 4:22 am
ODA1 wrote:
those with early vitara's can buy a jap wreck import centre console
( with cup holders ) for $20 and repace the original :D
hmmmmmm you got my interested ... will this work for a 93 lwb vit?
Vehicle: SJ80
Post Posted: Tue Jul 21, 2009 3:51 pm
paulv wrote:
Damo wrote:
Should be any year model, as long as it's a LWB. The 2.0 V6 ones are slightly bigger again.
Ok. So a brake caliper from a LWB 2.0 V6 Vitara bolts up to the same caliper mount bolt holes as the original Sierra one?
Excellent!
The Grand Vitara calipers are different?
GV are different rotor offset, I think the 2.0 V6 is too but look on the DBA rotors site to see
OK, so according to the DBA site for rotors:
Older Sierras use a DB 510.
290mm Diameter, 46.5 High, 10 thick, 107mm center hole. 5 stud holes
96 on (coilys) & 1.6 Vitaras use a DB 513
2.0 Vitara use a DB 518
310mm Diameter, 46 high, 22 thick, 107 center hole. 5 stud holes.
So does this mean the calipers and 290mm rotors for all sierra's can be changed over for the 2.0 Vitara 310mm ones?
Or only the older 290mm setups changed for the newer 290mm setups?
Vehicle: SJ80
Post Posted: Fri Jul 31, 2009 2:14 am
Has anyone successfully installed the 310mm 2.0L Vitara rotors and Vitara calipers on Sierra?
Did everyhting bolt up ok? or were modifications required?
Vehicle: Clown Car..
Post Posted: Thu Sep 03, 2009 5:29 am
TTT for the newbies :)
Post Posted: Sun Oct 25, 2009 2:42 pm
well i just got some valve extentions & some indicator fluid from some old guy in exchange for my cow.
I would engage you in a battle of wits, but I refu
Post Posted: Sun Oct 25, 2009 5:12 pm
Was the cow still alive? If it was you got jipped mate, I mean how many egg's were you getting of that cow a day?? :roll: 8O
Post Posted: Fri Nov 13, 2009 11:22 pm
well the funny thing is now i own a 93 lwb and i bought a set from a newer vit ( $20 :lol: )
I drove around for weeks going mental with out them :lol:
and i added a icebreak holder too :twisted: :roll:
Post Posted: Sat Nov 14, 2009 12:48 am
ODA1 wrote:
i thought that was a bong holder & the cup holders were in the console?
Post Posted: Sat Nov 14, 2009 12:50 am
:rofl: :rofl: Just thinking of Tim bent make's me laugh!! :rofl: :rofl:
Post Posted: Tue Nov 17, 2009 3:51 am
REMOVE SWAYBAR!!!!!!!!!!!!!!!!!!!!!
Sierra:pull leaves out and clean up and cut off spring clamps
Sierra:extended shackles
Vitara:strut mount flip
does that give more flex?
Heeyy Haterzzz :lol:
I Love AZ!!! and the controv
Post Posted: Tue Nov 17, 2009 1:15 pm
:lol: :lol: :lol: :lol: :lol:
Post Posted: Tue Nov 17, 2009 1:16 pm
Yeah, the sway bar restricts the front end significantly
Vehicle: 92 Suzuki Sierra
Post Posted: Sun Mar 31, 2013 6:14 pm
Searched cheap mods as i am thinking of inexpensive stuff for my LWB resurection, posting rather than creating a new thread, perharps these last 5 years will bring fresh ideas.
- Replace sierra wheel nuts with chrome Vitara ones. Other than the added bling i like to think the enclosed heads keep the threads free of muck and the elements.
- small auxilary In line fuel filter running between mechanical fuel pump and carburettor. Collects gunk that has accumilated in line or broken micro-bits of fuel pump.
- Vitara vicious fan for sierras (haven't actually done this keep forgetting to organise the studs!)
- Volt-meter positive battery terminal
Paid $29 for the one in my SWB, they are curently $19.95.
However i am going to be exceptionally stingy and put a ebay $3 mini digital voltmeter ( 3.0-30v) and momintary switch wired to ground in the LWB as i have fresh brass terminals.
Anyone else got stuff to add???
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun Mar 31, 2013 7:12 pm
:beer: love this thread
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Mon Apr 01, 2013 7:02 am
Built4thrashing wrote:
brake upgrade for sierra and SWB vits.
use LWB vitara front rotors and calipers. Completely bolt on. in sierra you need to trim stone guard and caliper needs to be removed and rotated to bleed properly.
(LWB vitaras have vented discs and larger pads.)
i know this is an old post but will the lwb brakes fit under 15 inch rims?
Post Posted: Mon Apr 01, 2013 10:23 am
Yes
Post Posted: Mon Apr 01, 2013 10:25 am
To clarify 1.6l LWB Vitaras fit.
Post Posted: Mon Apr 01, 2013 11:33 am
downlight fitting makes an awesome reverse light
cheap, easy mod that makes a difference
Users browsing this forum: No registered users and 40 guests
