It is currently Thu Oct 22, 2026 12:44 pm
Post Posted: Tue Oct 27, 2009 10:17 pm
I got my gti motor in wired up with the std comp she has spark injector pulse and fuel press but wont start :cheers: fuck fuck fuck Its giving me the shits anyone want to come have a look I cant figure it out
 Profile YIM
Post Posted: Wed Oct 28, 2009 12:27 am
Does it have compression? Did you play with timing? Does it have an engine check light?
Post Posted: Wed Oct 28, 2009 1:26 am
i had a similar prob.. i thought it might have been the timing, a wiring prob, etc etc.. turns out it was the coil!! was only sitting around for 8 months before i put it in, but that was enough time for the coil to die!! might be worth a check!
F&R ARB air lockers, lux diffs, 4 link coil rear,
Post Posted: Wed Oct 28, 2009 2:14 am
Will check it out and yes has compresson just rebuit the motor
 Profile YIM
Post Posted: Wed Oct 28, 2009 2:20 am
if its a type one you can get the tps and airflow sensor mixed up.....they have the same type plug.........
Post Posted: Wed Oct 28, 2009 10:46 am
I will double check joe but I think the plugs were diferent
 Profile YIM
Post Posted: Wed Oct 28, 2009 12:37 pm
Just thinking it might have dry rings since it's just been rebuilt leading to minimal or no compression.
Post Posted: Wed Oct 28, 2009 5:01 pm
Joe the airfow wiring go's directly into the harness no plug
 Profile YIM
Post Posted: Thu Oct 29, 2009 2:55 pm
:D :D :D Got it running yay turned out to be a wire that runs from the neg coil to the ecu some sort of pulse wire the auto elec sorted
it Im just happy to see it run :D
 Profile YIM
 Profile YIM
Post Posted: Thu Oct 29, 2009 7:12 pm
Was it a brown wire, always be on the look out for the brown wire when doing the gti conversion 8O
Post Posted: Thu Oct 29, 2009 10:24 pm
yep brown wire
 Profile YIM
Users browsing this forum: BZOOK and 142 guests
