It is currently Fri Oct 23, 2026 12:53 pm
Vehicle: jimny
Post Posted: Thu Nov 05, 2009 8:07 pm
as above, do i need an engineers cert to do the conversion? or is it just a blue slip?
Post Posted: Thu Nov 05, 2009 8:09 pm
For an accurate answer, I would ring the NSW road traffic authority.
Post Posted: Thu Nov 05, 2009 9:23 pm
If it is a motor that is not fitted from factory in that car it needs to be engineered. meaning if it is a different base motor.
Post Posted: Thu Nov 05, 2009 9:26 pm
athol should do it tho his not passing 31s on zooks anymore... and 33s are his limit on lux conversion
Post Posted: Fri Nov 06, 2009 12:40 am
When I did mine (recently) it does need to be engineered although its a minor thing. Cant remember the exact wording but its somthing like a v6 dunnydore would be a "conversion" but a vit 1600 is a swap as its such a small increase and its still suzuki and all but bolts in.
Dont quote me on the wording but you get the idea.
Nik
No zooks just VWs
Post Posted: Fri Nov 06, 2009 12:48 am
mine is engineered for the g16b.I showed him the engine mounts and the adaptor plate for the box.He barely cared tho as hes seen so many done and knows its bolt up.
Its on the report as just being replaced with 1.6 from vit bla bla.His main concern was that all polution gear was correct and cat/exhaust was good.Then commented on neat wiring.Then the partial blue slip for all the mods on the report were smooth sailing
Vehicle: jimny
Post Posted: Fri Nov 06, 2009 1:12 am
which engineer did your certificate?
Post Posted: Fri Nov 06, 2009 1:30 am
phill scott automotive.
Located around grafton area,nice bloke knows his shit.Has recently passed two zuks in town here with lux diffs 35s etc.He drives them etc and wont pass them if they aint good.
Was more worried about my loose steering box then the motor
Vehicle: jimny
Post Posted: Fri Nov 06, 2009 1:46 am
shit i reckon grafton is about 650km out of my way
Post Posted: Fri Nov 06, 2009 3:11 am
yeh i ment to add that.He drives to you....well did to me anyway.He does alot of the north west about every 3 weeks he comes here.But still as big a drive,dont know how far he goes.
Post Posted: Fri Nov 06, 2009 10:25 am
If you use a newcastle based engineer be careful which one you pic...
Btw what year did vits come out with cat converters or did they always have them?
Nik
No zooks just VWs
Post Posted: Fri Nov 06, 2009 4:58 pm
haha i know who your refering to... 8)
Post Posted: Fri Nov 06, 2009 6:04 pm
Nik
My carb 91 sierra had a cat convertor..
Post Posted: Fri Nov 06, 2009 6:21 pm
Nik
Anything that came from factory ULP has a cat, 88 or 89 I think was the change over from leaded.
Post Posted: Fri Nov 06, 2009 10:34 pm
The reason Im asking is I have a vit motor that I bought of my hairdressers sisters butcher neighbour and all I know is that its NOT stolen and its now legaly registered in myt zuk.
But the rta have said find out what model its from and if they came with a cat. Fit one if it did but dont if it didnt so they have left if open for me.
Now I wouldnt take a cat out of a vehicle that had one but my 85 model didnt have one and its been left open wether I fit one I just have to say what year its from If you read inbetween the lines they have given me.
Normally Id just do it but with all the hoops Ive had to jump through (offsett on rims 5mm to much so 4 new rims etc) Im running short on cash :cry:
Nik
No zooks just VWs
Post Posted: Fri Nov 06, 2009 10:39 pm
If it's efi you need a cat, if thay don't care, leave it as is.
Post Posted: Sat Nov 07, 2009 12:12 am
Not correct.
Depends on the catergory of vehicle and the relevant ADR it needed to be compliant with.
Many vehicles like 4wd's and commercial vehicles were exempt from certain ADR's when they were built, including Emmission Standards.
1986 was the changeover year from ADR 27 to ADR 37/00 and 1997 was when ADR 37/01 came in, then from 2003 they've been superseded by ADR 79/xx (euro standards).
So any vehicle built between 1986 to 1997 which was exempt from ADR 37/00, good chance it's unleaded, possibly even EFI and doesn't have a Cat Convertor and not required to.
Still doesn't help Nik out, but it's just to point out that an unleaded vehicle doesn't necessarily have to have a cat by law, depending on what it is.
Post Posted: Sat Nov 07, 2009 12:17 am
Trojan wrote:
Not correct.
So you are Tron!!!
Post Posted: Sat Nov 07, 2009 12:18 am
Ok different question, what was the 1st year of vit 1600?
Nik
No zooks just VWs
Post Posted: Sat Nov 07, 2009 2:32 am
how could he not pass it anymore if he did? so he was dodgy passing them before?
navara on 33s. hopfully rear air locker soon
Post Posted: Sat Nov 07, 2009 4:11 am
Nik
88 im pretty sure
Post Posted: Sat Nov 07, 2009 11:42 am
Wouldn't say he was dodgy passing them before.
The RTA changed the goal posts on what's required to pass larger diameter tyres. My understanding is anything larger then 2" they now want an abridged brake test done on the vehicle as apposed to just a normal brake test. Once you look into whats involved in that, it's quite costly and fairly harsh on the vehicles tyres and brakes.
Post Posted: Sat Nov 07, 2009 2:13 pm
On the topic of cat converters..
Does anyone have, or can tell me if an 87 LWB sierra came with a cat or not? At the moment mine doesnt have one but I was planning on putting one in so I dont get fined, but if they didnt come with one then I wont waste the money.
Member of C.O.R 4x4
Post Posted: Sun Nov 08, 2009 12:56 pm
Thsoe new laws I believe have not become effective yet because of the backlash of the 4wd community when they were announced. The state government was in talks with 4wd groups to make the law feasible to 4wd owners.
Post Posted: Sun Nov 08, 2009 1:19 pm
The abridged brake test thing was around before VSI50 raised it's ugly head. It's only one of those requirements of proving your brakes are still up to the task of stopping a vehicle with much larger tyres.
Some engineers are still getting around it somehow, whilst other just won't do it.
Post Posted: Mon Nov 09, 2009 10:20 am
So if vits came out in 88 they probly all had cats?
I may have to do the abridged brake test yet to confirm my braking system works now if gone to lux diffs but we are trying to get around that.
Nik
No zooks just VWs
Users browsing this forum: Google [Bot] and 140 guests
