It is currently Thu Oct 22, 2026 7:53 pm
Post Posted: Tue Nov 10, 2009 7:22 pm
I've done the upgrade but I can't hook the air con up as it's not a multi-rib pulley. Can I upgrade the pulley (clutch pulley) or will I need another compressor? (swift?)
cheers,
Jimmy.
Post Posted: Tue Nov 10, 2009 7:48 pm
Cant u just use the standard alternator pully?
Post Posted: Tue Nov 10, 2009 7:55 pm
nah can that idea, different size shaft in the alt
Post Posted: Tue Nov 10, 2009 9:50 pm
dont get it, aircon and alternator run on different belts?
Post Posted: Tue Nov 10, 2009 10:10 pm
To do the alternator upgrade, the water pump and crank pulleys had to be swapped for the swifts multi ribbed pulleys. The air con pulley isn't multi ribbed so it can't be hooked up to the crank pulley. So pretty much, I either need to replace the air con pulley or replace the entire compressor...
(I'm presuming replacing the clutch pulley will be a pain in the arse?)
Post Posted: Tue Nov 10, 2009 10:31 pm
so you have 2 multirib pulleys on your crank now?
assuming you have aftermarket aircon with a sanden compressor its probably not a lot of effort to get a new pulley fitted to it
Post Posted: Tue Nov 10, 2009 11:41 pm
Yep, two on the crank.
I'll swing past the wreckers and see what they've got on offer.
Post Posted: Wed Nov 11, 2009 7:08 am
If you run a Vit W/Pump pulley, you don't need to change the water pump.
I've asked Lowrange Offroad if they'd do a custom version of their 1.6 pulleys (5 bolt crank) in a 1.3 style (4 bolt crank) specifically for a Falcon Alt conversion, and also with a 4 bolt crank with 2 multi rib pulleys for On-board Air type air compressors.
They are going to get back to me. Any interest in a Group Buy if they say YES?
Post Posted: Wed Nov 11, 2009 11:53 am
i used the pulley and clutch of a swift aircon compressor, bolted straight on
with no problems. at least i think it was a swift cos i found it in a creek.
Post Posted: Wed Nov 11, 2009 11:56 am
I'd be keen.
Just confirming that the above pulley will replace the crank pulley and has two pulleys built in, the innermost one multi ribbed (for alternator, water pump) and the outermost one vee-style (for air con, air compressors etc)
Post Posted: Wed Nov 11, 2009 11:58 am
haha awesome :lol:
So the clutch pulley isn't a PITA to swap over then? If it's a stright bolt-off, bolt-on job then i'll swing past the wreckers.
Post Posted: Wed Nov 11, 2009 3:04 pm
the crank pulley i found was a multi rib twin belt pulley and i also used the swift aircon clutch. i got
the alt pulley from a sparkie to match the rest of the pulleys but only as i couldn't remove the swift pulley without busting it. there are photos here somewhere of the setup.
Post Posted: Wed Nov 11, 2009 3:05 pm
probably need a rattle gun to get the aircon pulley off as it is hard to hold.
Users browsing this forum: No registered users and 192 guests
