It is currently Sat Oct 24, 2026 10:16 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Tue Nov 17, 2009 5:25 pm
heres the JT's we picked up, only 3 days till we pick it up and start gettin down to buisness
Vehicle: 1987 sierra tray back buggy
Post Posted: Sat Nov 21, 2009 5:25 am
picked up james today, tray is off, dash, steering, seats all interior, engine is out and tomorrow it will be stripped down to a chassis and the suspension will be started on, cheers to Dave at coastals for the set of leafs mate, will be coming back for more gear later down the track for sure
Post Posted: Sat Nov 21, 2009 5:40 am
Post Posted: Sat Nov 21, 2009 5:42 am
thats the fuel line plug :D
Post Posted: Sat Nov 21, 2009 5:53 am
Cool im looking forward too watching this build up come along :goodjob:
Post Posted: Sat Nov 21, 2009 12:49 pm
Hell yes. Weight reduction, Wash it!! :P :roll: :wink:
Start up a rig's thread :comeon:
Post Posted: Sun Feb 07, 2010 4:29 am
just a few pics of todays work. been a while since anything has happened
The rear 3/4 eliptical setup. fabbed up and taked on i hope its right.
another one of the 3/4
the front suspension mounts welded on and the beefed up front cross member.
w/t diff marked out so the spring perches can be moved to suip the n/t. the rear diff was also dont today.
so it starting to coma along quite nicely now.
few more bits and pieces on the suspension and it should be back on the wheels.
MODERATORS could you please posibly move this thread to the rigs section.
Post Posted: Sun Feb 07, 2010 4:50 am
Im a dick when i looked at the first pic i thought to myself why would you have a spring on top of the chassis :roll:
On a differant note :goodjob:
Post Posted: Mon Feb 08, 2010 2:21 am
So guys i have a baleno motor to go into this build and have all the power steering gear from the car that it came out of, infact iv still got the car in the front yard. anyway what are your thoughts on being able to use the power steering from the baleno in the sierra?
and here is the progress for this morning.
the front w/t diff spring perches moved 57 mm in to match the n/t
new rear mounts for the front springs as we have gone RUF of sorts.
the front springs in place waiting on bushes to make it all a bit more solid, and there are a set of more solid shackles in manufacture.
also got the front mounts welded up and the rear 3/4 welded on fully and am waiting on bushes to mount up the suspension. then we can mount up some shockies.
Post Posted: Mon Feb 08, 2010 3:09 am
Putting helium in those tyres to drive the sky? skys the limit eh? :lol:
She's gonna be heavy to turn over!
Is this going to be on the road?
Post Posted: Mon Feb 08, 2010 3:19 am
Another first layer of gravity thing??
Given the "trailer queen" title I don't think it's going on road.
Post Posted: Mon Feb 08, 2010 3:23 am
Looks like its going to be scary offroad let alone onroad! :? :lol:
Post Posted: Mon Feb 08, 2010 4:08 am
ahhh how so? you realise the chassis is sitting upside down right?
Post Posted: Mon Feb 08, 2010 4:20 am
what are you doing for driveshafts?
this is going to be crazy high.
hope you dont have side angles in perth.
Post Posted: Mon Feb 08, 2010 4:24 am
also curious as to how your going to set up the steering?
Post Posted: Mon Feb 08, 2010 3:16 pm
it will be alrigth those springs will sit virtually flat with a body and an engine in there. its also going to be a good deal wider than when it started. be we,ll see how we go. 8)
Post Posted: Mon Feb 08, 2010 3:27 pm
You do realise they are used springs dont you ?
Other then the overly large front chassis mounts which I assume is because of the shackle reversal it shouldnt be too bad.
Post Posted: Mon Feb 08, 2010 3:37 pm
got it in one red and the rear 3/4 sits flat when on the flat and can be pinned in place. so it will only open up when its un pinned and we drop a wheel in a big hole. 8)
also i was thinking of fabing up some square drive shafts and if need be taking them to a drive shaft place to balance them but im not sure they will need to be balanced for what we want.
Post Posted: Thu Mar 04, 2010 12:04 am
another pic for u all
Post Posted: Thu Mar 04, 2010 5:29 am
what is holding the front mount on the rear spring?
Post Posted: Thu Mar 04, 2010 6:02 am
Where is the front flex?
Post Posted: Thu Mar 04, 2010 6:10 am
100x100 welded to the chassis, its because the chassis bends in it needed to be steeped out, ghetto speck mothfukle engineering style
i come from ifs lol thats good front flex lol
Post Posted: Thu Mar 04, 2010 11:04 pm
you might want to limit the rear as she will flop all over the place with that rear end... JMHO
Post Posted: Thu Mar 04, 2010 11:28 pm
True.
But You would be better off limiting the rear flex and then modding the front end so that it flexes the same as the rear. This way you will have a far more predictable vehicle.
Post Posted: Thu Mar 04, 2010 11:32 pm
my 3/4 doesnt flop all over the place ???
after doing RUF i found the extra flex in the front made the rear work
even better, hardly lifts a wheel at all now. My front shackles are quite angled now and hit a fair bit on vertical rocks but bigger tyres should fix that.
Post Posted: Fri Mar 05, 2010 12:29 am
im unsure about alot of things but the 3/4 when its done flopping about is not one of them. it is a simple up down flex setup when finished with a panhard rod on the rear diff and a set of guides for the 3/4 spring. it is simply the same as those extendable shackles. it cant unload unless you take weight off it by dropping a wheel in a rut etc so its not something that is unpredictable at all in my oppinion.
ps it may look ag spec but it is over engineered big time the suspension mounts on this thing would be right at home on a patrol.
here are some more flexual pics for you all.
Post Posted: Fri Mar 05, 2010 1:15 am
mate nobody said that 3/4 was unpredictable.
What I said was that having massive flex at one end, and none at the other makes a vehicle unpredictable. You just need to sort out the front end. Then it will be a weapon!!
Post Posted: Fri Mar 05, 2010 1:35 am
no worries fat zook. i got ya now. we actually getting really good flex out of the front too the limiting factor on both the front and rear flex is the front tyres coming back into the firewall. i also think that with a panhard on the rear and maybe the front it will sure things up nicely. the major problem at the moment as can be seen from one or two of the pics is how the rear is slewing sideways wen the front is lifted but hopefully that will be fixed by the end of the weekend with the addition of a home grown panhard from the panhardius tallus tree 8)
Post Posted: Fri Mar 05, 2010 3:01 am
This thing looks mad :P i cant wait too get my own trayback :roll:
Post Posted: Fri Mar 05, 2010 3:43 am
just redrill the perch and move the diff forward a bit, you will be suprised how much difference it makes in relation to the scrub issue
Users browsing this forum: No registered users and 100 guests
