It is currently Thu Oct 22, 2026 7:53 pm
Post Posted: Sun Nov 22, 2009 3:45 am
My pinion seals have started leaking. So im going to have to change them im just wondering where people have got the seals from and if the front and rear seals are the same.
and do they come in a kit?
cheers
Post Posted: Sun Nov 22, 2009 3:52 am
There is a crush tube that put load on the pinion bearing, very good idea to replace it, I think suzistore sell em, Low range do.
I have used washer's to shim them up, but that was bodge of me :roll:
worked but.
Post Posted: Sun Nov 22, 2009 3:58 am
does the crush tube come in the kit im guessing when i change the seal ill have to reset the backlash on the r&p
Post Posted: Sun Nov 22, 2009 4:09 am
Don't think so. I think, if memory serves, you can replace both in car.
Just remove shaft, undo flange nut & remove flange, pull seal out & tube "should" come out, then you just fit the new stuff.
I think it can be done in car, but don't hold me to it, If it can than the back lash won't have to be set again as your not moving the crown wheel.
Post Posted: Sun Nov 22, 2009 4:21 am
yeah ok sounds good thanks bud
Post Posted: Sun Nov 22, 2009 1:49 pm
http://www.suzistore.com.au/shopexd.asp?id=222
Here's a kit, The crush tube is the tube looking thing :roll: 8O :wink: :lol:
Post Posted: Sun Nov 22, 2009 1:54 pm
Another one, bit cheaper to :roll:
http://www.lowrangeoffroad.com/samaxles.htm
Post Posted: Sun Nov 22, 2009 2:38 pm
Getting the crush tube tightened correctly is a total pain in the ass.
Had to fab up a bracket and pole to bolt to the pinion flange, then get a piece of pipe on the socket.
Even being very careful, I still ended up slightly over tightening
Post Posted: Sun Nov 22, 2009 2:52 pm
Hand brake? :roll: If it's still in the car the car has it's own mean's of stopping the pinion & diff from turning.
Post Posted: Sun Nov 22, 2009 4:10 pm
What if it has transmission brake? :roll: :roll: :roll: :roll: :P
Post Posted: Sun Nov 22, 2009 4:16 pm
Whhel chocks
Post Posted: Sun Nov 22, 2009 4:18 pm
leave the wheels on the ground and lock in the front hubs and if you have a 2nd person get them to stand on the brakes. This works for undoing t/case nuts.
Post Posted: Sun Nov 22, 2009 4:59 pm
HULLOW!!!!!! 2nd peddle from the left or right, the middle one!!!!
You could use that!!!! :thefinger: :thefinger: :roll: :roll:
Post Posted: Sun Nov 22, 2009 5:46 pm
i have the same problem, with my rear cept its full of swamp water and oil :S,
doinga a drain today and gotta replace the rear pinoin seal,
advice??
Heeyy Haterzzz :lol:
I Love AZ!!! and the controv
Post Posted: Sun Nov 22, 2009 8:10 pm
advice??
Look up the top of this tread?? :roll: :? 8O
If it's full of water I'd be getting that out, fill with iol & see if it leak's..
Post Posted: Sun Nov 22, 2009 9:35 pm
both of those kits must be a full diff centre rebuild kit am i right?
Post Posted: Sun Nov 22, 2009 9:36 pm
steknig wrote:
No, above the master re build, has the tube,nut & seal.
Post Posted: Sun Nov 22, 2009 9:51 pm
are missed that one cheers
Post Posted: Sun Nov 22, 2009 9:54 pm
That's ok.
Post Posted: Sun Nov 22, 2009 10:38 pm
should only be the pinoin seal rght?? i hope :S
Post Posted: Sun Nov 22, 2009 10:40 pm
With water in your diff you may have caused damage best to pull the center out and Check bearing etc before getting parts
Post Posted: Sun Nov 22, 2009 10:48 pm
Have you read any of this??
I even replied to your last question.
Post Posted: Mon Nov 23, 2009 1:40 am
you mentioned a crush tube lad..
Post Posted: Mon Nov 23, 2009 1:47 am
advice??
I Also said this
Watered down oil will leak out where oil won't, it's worth a go.
Post Posted: Mon Nov 23, 2009 1:56 am
yes well.. its ordered any ways, leat ill have a spare i guess,
gotta replace diff oil any wayzzzz
thanks post whore
Post Posted: Mon Nov 23, 2009 1:57 am
thanks post whore
:lol: O k.
Users browsing this forum: No registered users and 187 guests
