It is currently Thu Oct 22, 2026 9:13 pm
Post Posted: Sat Nov 28, 2009 5:08 am
I'm not sure if I'm right if dieseling is what's happening when I turn ignition off. Sometimes engine runs for a second or more once I turn ignition off. Is it fuel solenoid or something else. If it is solenoid is it expensive and hard to replace? I don't even know where is it in the engine. If I don't replace it will something break down eventully? Any sugestions. Thx
Chris
Vehicle: 1995 Sierra 1.3
Post Posted: Sat Nov 28, 2009 7:21 am
What you're describing is Dieseling (engine running on). It is normally caused by the engine timing being out. A good service with fresh plugs, oil and filters is a good start. If you know someone with a timing light, get them to check the engine timing for you as well.
Post Posted: Sat Nov 28, 2009 12:44 pm
This will help.
Also you eng could be idling to high or running to hot.
have a look here to. http://www.auszookers.com/index.php?nam ... c&p=111984
Vehicle: MY2019 Jimny
Post Posted: Sat Nov 28, 2009 2:10 pm
Hey Chris!
Your timing may be advanced a bit, I don't remember you mentioning cooling issues at all?
Post Posted: Sat Nov 28, 2009 4:01 pm
thx, timing might be out, but it's idling too high for sure. I'll turn it down and see how it goes.
Post Posted: Sat Nov 28, 2009 4:05 pm
If it's idle is to high the fuel get sucked past the idle stop, effectively bypassing the solenoid.
Choke may not be turning off.
Post Posted: Sat Nov 28, 2009 4:12 pm
Or vacuum leak
Post Posted: Sat Nov 28, 2009 4:20 pm
If it doesn't stop running you can always stall it, unless you are low first!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 322 guests
