It is currently Fri Oct 23, 2026 10:20 am
Post Posted: Mon Nov 30, 2009 12:51 am
I have a whine coming from the gearbox or transfer case. i'm leaning towards the gearbox as the noise is from 3rd gear to fifth and it doesn't matter whether the transfer is in high or low range. Also when the you let the clutch out in nuetral the car moves forward slightly.
What are your opinions?
Vehicle: MY2019 Jimny
Post Posted: Mon Nov 30, 2009 1:04 am
Mine lurches forwards when the clutch is let out in neutral too, no issue there.
Post Posted: Mon Nov 30, 2009 1:14 am
yeah thought it might have had something to do with the whine if its in the gearbox, but mustn't do
Post Posted: Mon Nov 30, 2009 1:49 am
put the car up on jack stands and then talk someone into laying under the car, then run
it through the gears and ask them where the noise is coming from. :wink:
Post Posted: Mon Nov 30, 2009 2:04 am
That's what mother in-laws are for...
Much safer on a hoist though. :wink:
Post Posted: Mon Nov 30, 2009 4:14 am
Did it whine in 4th and 5th previously, then progress into 3rd gear whine too.
I would suspect the gearbox needs new bearings.
Post Posted: Mon Nov 30, 2009 10:42 am
jacking it up and having it going might be a problem, because it has no engine or gearbox at the moment.
The whine is only just noticable in 3rd gear, but gets louder as soon as you go to 4th, i hvaen't had the car that long so im not sure if it was only in 4th and 5th
Post Posted: Mon Nov 30, 2009 12:40 pm
when the rear wheel bearings are stuffed they can sound like it is coming from the gearbox.
Post Posted: Mon Nov 30, 2009 1:25 pm
In that case, pull out the transfer case, split it and have a look at it's condition.
Users browsing this forum: Google [Bot] and 345 guests
