It is currently Fri Oct 23, 2026 12:26 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Post Posted: Fri Dec 04, 2009 2:30 am
does anyone know the centre distances (middle of pipe to middle of pipe) of the sierra 1.3 litre engines? are they the same as the gti twin can swift engine? is it the same flange plate? need extractors for gti engine, ebay 200 bucks delivered, good deal?
Post Posted: Fri Dec 04, 2009 2:48 am
Sierra extractors line up with the ports but you need to change the flange with GTI one also you need to put the O2 sensor in shop around for some 2nd hand ones I picked up Sierra ones for $20 and the GTI ones came on my motor I wouldn't pay $200 for something you going to cut up
 Profile YIM
Post Posted: Fri Dec 04, 2009 4:20 am
i actualy made my extractos.. .dodgey but they work, i used a set of mk1 extractors and cut the pipes and rewelded bits.. works but yeah that was only because i couldnt get coily extractors at the time
Post Posted: Fri Dec 04, 2009 4:33 am
pm sent
Vehicle: Jeep
Post Posted: Fri Dec 04, 2009 7:11 am
Hiya,
I just bought some extractors for my 89 Vit with the G16A engine, off of ebay to, mine were $220 delivered, which is over $100 cheaper than others i got quoted !
I just received my extractors today, they may be cheap in price, but they are definitely not cheaply made, they are very well manufactured with thick powder coated steel, i am very happy with them !
And i get them, the extractors, and a sports system fitted tomorrow, he he, cant wait :rofl:
:woohoo:
Post Posted: Fri Dec 04, 2009 11:55 am
thease are my extractors gti flange plate / sierra tubes
 Profile YIM
Vehicle: 92 Suzuki Sierra
Post Posted: Fri Dec 04, 2009 6:36 pm
is it just me or the pic... but is that flange of yours like real thin sheetmeal?
-Santos
Vehicle: 95 Sierra Soft top
Post Posted: Fri Dec 04, 2009 8:04 pm
Nah it looks thin mate lol i was thinking the same thing even before i saw ur post :lol:
Post Posted: Fri Dec 04, 2009 9:45 pm
Na the head tapers out at the top makes it look that way
 Profile YIM
Vehicle: Jeep
Post Posted: Sat Dec 05, 2009 6:06 am
Hi Jimbo,
Not bad for home made extractors :wink: idealy, the pipes coming off the manifold, should all be the same length before they join up into one, thats what i think they call, tuned... but hey, still a good job Jimbo :wink:
Well i got my extractors and sports system fitted to day yess!!
But, i told the guy i wanted everything new and 2inch right through, and he decided to leave the old caty converter on, because it looked clean and still in pretty good nick :x so i have 2inch extractors going into an old 1 1/2 inch caty, then back to 2inch into the sports muffler :x i told him i wanted everything new... spewin :x so i will have to pay another $300 to get a new 2 1/4inch caty fitted now...
The only good news out of it all, is that the G16A engine has heaps more top end torque and speed now, with less pushing of the old go pedal, and it also has a pretty good exhaust sound now :wink:
Post Posted: Sat Dec 05, 2009 2:28 pm
It's a 4by, so Idealy thay shouldn't leak, you wouldn't notice the diffrence between tuned & jimbo built on a std eng :roll: 8O :P
Nice work jimbo, 8)
Post Posted: Sat Dec 05, 2009 7:04 pm
thanks steaknife the extractors a of the shelf type for a sierra with the sierra flange cut of and the gti flange welded on I never made the extractor tube's they came like that and they run into the factory exhaust system its a rock crawler not a drag car dose the job fine
 Profile YIM
Post Posted: Sun Dec 06, 2009 4:38 pm
Jimbo, so the sierra extractors dont need any mods except the flange plate and the O2 sensor? most people running 1 1/2" primarys? found a set on ebay, the MPH set for 200 bucks, sound ok?
Vehicle: Jeep
Post Posted: Sun Dec 06, 2009 9:15 pm
They are more than ok, they are excellent :wink:
I just got the MPH and they are a quality product !
I have found that they put out alot of heat, and my aircon pipe is only 4inches from them, so i may have to get some asbestos cloth to rap around it, as the aircon pipe is getting very hot now, oh well, easy fix lol, i am very happy with the MPH extractors ! :wink:
Post Posted: Mon Dec 07, 2009 1:26 am
yes they will work fine, also if you use the gti flange gasket as a template you can make the gti flange
 Profile YIM
Post Posted: Mon Dec 07, 2009 2:16 am
nah, like jimbo said, they line up perfectly! Heres a pic of the sierra flange with gti extractors so you can see the ports line up perfectly with no bending or anything needed. (didnt need the gti extrators though)
(sierra flange plate with kind of square holes)
And a pic of how the sierra extractors with gti flange plate looks on the car. You will have to drill a hole and get a nut welded on because the g13b has a o2 sensor that needs to go in. Or your exhaust shop would do these all the time..
Also like jimbo said you can make your own flange by using the gasket.. Depends what machines and tools you have though. Was only $70 for flange and gasket (gasket costed $30 by itself!)
Post Posted: Mon Dec 07, 2009 2:19 am
just bought a set from MPH, and will get my flange plate plasma cut at work, all sweet. engine is sitting in, making mounts for it this week at last. post some pics tomorrow night. cheers
Post Posted: Mon Dec 07, 2009 3:15 am
what do you mean "making mounts for it" the motor use's the factory engine mounts
 Profile YIM
Post Posted: Mon Dec 07, 2009 10:46 pm
using the factory engine mounts but the brackets on the chassis are in a different spot than the 1.3 litre, so the engine doesn't fit where i want it, so i'll make my own, giving me another 25mm clearance for the distributor cap to the firewall
Post Posted: Tue Dec 08, 2009 12:18 am
pic of engine sitting in place, exhaust, engine mounts, radiator and wiring to go
Post Posted: Tue Dec 08, 2009 1:52 am
ahh ok was this a 1.0ltr before? are you using the gti dizzy? if so use the mazda dizzy cap gives you mor clearance
I did a rite up not long ago Ill have a look for the thread :wink:
 Profile YIM
Post Posted: Tue Dec 08, 2009 1:57 am
here it is
http://auszookers.com/index.php?name=Fo ... dizzy++cap
 Profile YIM
Post Posted: Tue Dec 08, 2009 10:26 pm
dizz cap i sorted , stuck it in the lathe and machinined it to the right size. what does people do with the water outlet. heard that the mitsubishi thermostat housing is the go, bought one, but looks dodgey to make it fit.
yes Jimbo, did have 1 litre in there, it sucks making new mounts, but has to be done. it means i can put the engine where i want anyway. keep you posted in how i go.
Post Posted: Tue Dec 08, 2009 11:14 pm
:shocked: :shocked:
You did what???? 8O :? :?
Post Posted: Wed Dec 09, 2009 2:51 am
Dont worry about using the mitsubishi one. I used one from a suzuki swift cino, its a perfect fit. Theyr'e the most common one at wreckers too.
Post Posted: Wed Dec 09, 2009 3:24 am
mines of a 85 barina/swift
 Profile YIM
Post Posted: Wed Dec 09, 2009 10:58 pm
zookfun
you got any part numbers for the thermostat housing from a cino. have to get one from motor traders, wreckers done here will charge me an arm, a leg, and my left nut for anything. they wanted $550 bucks for a 5 speed box, and i had to remove it from the car myself! pfff, 100 bucks from ebay!
Post Posted: Thu Dec 10, 2009 12:49 am
17561-63B01 should be about $30 genuine , but can find at any wreckers...
Post Posted: Thu Dec 10, 2009 1:26 am
I bought mine from a suzuki dealer because i didnt know they were so many at the wreckers..
Image[php]
edit- beaten!
Post Posted: Thu Dec 10, 2009 1:36 am
zookfun wrote:
I bought mine from a suzuki dealer because i didnt know they were at wreckers so not sure if the art number will be right or not..
Image[php]
That's the number he gave ya!! :wink:
Users browsing this forum: No registered users and 170 guests
