It is currently Sat Jul 25, 2026 11:10 pm
Post Posted: Fri Dec 11, 2009 5:33 pm
SO last weekend my breathers all got ripped off and both diffs, Trany and T-case filled with water. And seeing as I didnt know it happend my rear diff is now at reast (R.I.P.)
I have drained the milkshake out of the rest. Now I am going to hope there is no major damage in the rest of the drive train (FINGERS CROSSED)
The Question I have is should I flush them all out with something???
If so what have you tryed before???
I was just going to get some cheap gear oil and run it for a few days then drain it out.
Or do you just fill it up and go on with your day?
I normaly run Castrol 80W-90 as I get it cheap.
Any past expierance would be a help.
Vehicle: MY2019 Jimny
Post Posted: Fri Dec 11, 2009 5:40 pm
Yeah run some cheap gear oil for a few days, then drain it out. That is what I have done in the past...
Post Posted: Fri Dec 11, 2009 5:46 pm
yep. x2
Vehicle: jimny
Post Posted: Fri Dec 11, 2009 6:22 pm
maybe ask the castrol rep what he reccomends?
Post Posted: Fri Dec 11, 2009 6:25 pm
fill it with kero and run run it on a hoist for a bit to clean up the shit and refill it
or dont bother, the small amount left in there after you drain it wont matter
Post Posted: Fri Dec 11, 2009 7:12 pm
Go the kero.
Post Posted: Sat Dec 12, 2009 1:06 pm
x3
Post Posted: Sat Dec 12, 2009 3:56 pm
Kero will get into the grease and remove it too, no?
Post Posted: Sat Dec 12, 2009 8:36 pm
there should'nt be any grease in the tranny or tansfer case
Post Posted: Sat Dec 12, 2009 9:05 pm
In my rebuild instructions it says to put grease on the roller bearings...
Post Posted: Sat Dec 12, 2009 9:40 pm
I would say thats so they arent running dry straight up till oil gets flung to em
kero is a lubricant as well so should be ok
Post Posted: Sun Dec 13, 2009 12:20 am
just drain it and refill will be fine theres no need to flush like royce said the small amount left in there wont matter
 Profile YIM
Users browsing this forum: No registered users and 386 guests
