It is currently Sat Jul 25, 2026 11:13 pm
Post Posted: Mon Dec 14, 2009 8:01 pm
i cant seem to get my sump off, are there bolts behind the little metal piece attatched to the gearbox?
i need to get it off to replace the gasket, im just using the gasket goo cos i had some lying around and couldnt afford another $15 gasket
so anyway anyone got any ideas, pics would be a great help
btw its for a coily sierra
thanks, fletch
Post Posted: Mon Dec 14, 2009 8:07 pm
yes there are 2
Post Posted: Mon Dec 14, 2009 8:09 pm
thanks royce
any tips on removing a stripped hex head?
Post Posted: Mon Dec 14, 2009 8:11 pm
A triple square hammerd in normaly does the trick or a chisle and a hamer to get it loose then your fingers.
Post Posted: Tue Dec 15, 2009 12:27 am
you can also buy special sokets that will cover the bolt just as you turn it the soket has a sort of thread that shrinks and locks onto the bolt nice and tight making you able to remove it bunnings sell them they come in handy i cant remeber the name of them there in my brothers tool box
Post Posted: Tue Dec 15, 2009 12:47 am
coilyzook wrote:
thanks royce
If you can get to it with a grinder, use a thin cutting blade to make a slot right across the head of the bolt. Then get the biggest flat head screwdriver that you can find and swing like hell. The heat from the grinder should help break the bolt free.
Post Posted: Tue Dec 15, 2009 11:10 am
coilyzook wrote:
thanks royce
good pair of vice grips
Post Posted: Tue Dec 15, 2009 11:07 pm
irwins are what the sockets i was telling you about are
Users browsing this forum: No registered users and 281 guests
