It is currently Fri Oct 23, 2026 10:14 am
Vehicle: 98 Maruti
Post Posted: Sat Dec 26, 2009 6:33 pm
iv just found my front diff in my grand vitara has a crack running through the top of the casing. can the diff be wielded up as a temporary solution until i can find a steel diff?
also dose anybody have a steel diff that is in need of a good home?
Post Posted: Sat Dec 26, 2009 7:04 pm
take it to any specialist welding shop and they can weld it up good as new :D
Post Posted: Sat Dec 26, 2009 7:17 pm
x2. It's out and clean so anyone with a bit of skill should be able to weld it. I would still consider it a temporary fix though
Post Posted: Sat Dec 26, 2009 7:26 pm
no it's alloy or something so it's won't weld without a proper alloy welder..
Post Posted: Sat Dec 26, 2009 7:30 pm
I reckon another alloy housing will be a heap cheaper than getting that welded up
Vehicle: 98 Maruti
i have someone who can wield it, but what kind of wielder do i need would a tig work?
Post Posted: Sat Dec 26, 2009 7:32 pm
a high frequency TIG or a mig with the right wire and gas....
Vehicle: 98 Maruti
Post Posted: Sat Dec 26, 2009 9:08 pm
well i think il wield it with a tig while i sort out a steel diff. dose anybody know of a suzuki wreckers that might have one.
im located in darwin and no one has anything here
Post Posted: Sat Dec 26, 2009 9:17 pm
i may be able to bring it back for you if you can find one. :wink:
Vehicle: 98 Maruti
Post Posted: Sat Dec 26, 2009 9:24 pm
where abouts are you now shep? elco?
yea if you could find one that would rock
Post Posted: Sat Dec 26, 2009 11:49 pm
j
ust make sure you run reverse polarity (put a ball on the end of your tungsten), high frequence, use alloy filler wire and a different type of gas to normal tig work. it's all in setting up as im sure it will cost you bugger all to geta shop to do it. but tell us how you get on :D
Post Posted: Sun Dec 27, 2009 12:00 am
Take it to a head shop they will fix it up...
Post Posted: Sun Dec 27, 2009 12:04 am
port macquarie mate. be driving back through shitsland on the 1st.
Post Posted: Sun Dec 27, 2009 12:05 am
are you the fella that bought the MTR's and rims off me?
Post Posted: Sun Dec 27, 2009 12:08 am
j
to weld aluminium you need AC high frequence.depending on your machine you dont need need to ball the tungsten. probably with the old transformer machine you will have to ball the tungsten. if yourr using a transformer machine you a Zirconiated tungstem (white tip)
if you got an inverter type machine you can use thoriated tungsten with a point ground on it. thats what i uses for aluminium.
i could also say thats its porbably cast aluminum so you need to use 4*** series filler. not 100% what it is but have a look on cigweld web site and it has the fillers and there uses.
but ultimatly i could probably just get a new housing
navara on 33s. hopfully rear air locker soon
Vehicle: 98 Maruti
Post Posted: Sun Dec 27, 2009 12:22 am
yep mate
il send you a pm about the diff
i think my best bet would be to get a ali shop to wield it up, il keep everyone posted
Post Posted: Sun Dec 27, 2009 1:03 am
stick some photos of ya car up, there are a few people here that like the soft suzukis. :D
Vehicle: 98 Maruti
Post Posted: Sun Dec 27, 2009 1:25 am
just a peek, im doing a bit of a overhall on her atm, redone the sump gasket, rear main seal, still need to machine the flywheel and chuck ina new clutch and there are a few extra things like a touch more lift, a new snorkel for the wet and finish of my front bar
and the only action pic i have atm, when i mixed up the air lines going to the diff compresor and was flying around in 2wd
Vehicle: 98 Maruti
Post Posted: Mon Dec 28, 2009 10:08 pm
well im going to try get the diff wielded as a temporary solution while i wait and see if i can find a steel front diff
does anybody know what kind of aloy the front diffs are mad out of? so i can get some filler wire to match?
Post Posted: Tue Dec 29, 2009 1:56 am
i think it's a combo of melted down pootrol TB42 heads & heads from EA falcoon taxi's... :lol
i'm sorry to say this i chucked one of these alloy housings the other week, i would have gotten rid of it for the cost of postage. :oops:
does the ally diff out of a vitara fit these i might have one here ill have to check it for cracking
Vehicle: SV420
Post Posted: Wed Dec 30, 2009 4:54 pm
I am able to help here and I am in Port Macquarie :)
I have two alloy ones as I have already upgraded to steel housing.
Sent PM to experament-u2 and shep with my mobile number.
Post Posted: Wed Dec 30, 2009 5:49 pm
good on ya mike, hopefully he see's this soon as i will be making like a
donkey's dick and hitten the road very shortly :wink:
Vehicle: 98 Maruti
Post Posted: Thu Dec 31, 2009 12:28 am
a big thanks to mike and shep for helping me out
cheers to everyone else aswell
Users browsing this forum: No registered users and 348 guests
