It is currently Fri Oct 23, 2026 9:24 pm
Post Posted: Thu Dec 31, 2009 12:21 am
hi have a 87 stock sierra [tinny] she jumps out of low range every now and again only used on farm always driven in low range.pulled cover off swear curse jam rattle crunch and were back on the road my 12year old son drives most off the time has trouble getting back in
Post Posted: Thu Dec 31, 2009 12:26 am
check your transfer case mounts. one of them might be broken and the transfer case moves under load, causing the shifter to hit on the tunnel knocking it out of gear.
Post Posted: Thu Dec 31, 2009 12:32 am
or is the little shifter bush at the lever busted or non existant like mine was?
Vehicle: LJ80
Post Posted: Thu Dec 31, 2009 1:11 am
x2 it happened to me very easy and cheap to fix
Post Posted: Thu Dec 31, 2009 2:31 am
X3, also a very common problem.
Still worth looking at the t/case mount tho. :wink:
Post Posted: Thu Dec 31, 2009 3:03 am
x4 thats what I would be looking at first
Post Posted: Thu Dec 31, 2009 4:11 am
SOME TIMES YOU GET TRANSFER CASE WIND UP AND IF YOU PUT IT IN AND THEN REVERSE AND THEN DRIVE FORWARD IT MIGHT HELP
Post Posted: Thu Dec 31, 2009 4:12 am
Cap's lock :roll:
Post Posted: Thu Dec 31, 2009 4:13 am
steknig wrote:
Cap's lock :roll:
P.s, It's jumping out of low, not binding up.
Post Posted: Thu Dec 31, 2009 4:20 am
That bush is called a 'sheet', available from Suzuki spare parts.
Vehicle: '96 LWB trayback
Post Posted: Thu Dec 31, 2009 4:58 am
It's a pretty common problem that all sierra owners have sooner or later.
Go through the possible causes above and you'll get yourself out of trouble for sure.
I'd look at 3 causes in this order:
- Broken transfer mount rubbers, especially drivers side front.
- Check drivers side mount (plate) is straight and not bent, causing misalignment of the transfer case.
- Replace the transfer sheet. http://cgi.ebay.com.au/Transfer-Case-Le ... 35a4175faf
Post Posted: Thu Dec 31, 2009 2:47 pm
I'm pretty sure this isn't going to be the cause of the original poster's problem but for the sake of being thorough...
...this can also be cause by lack of clearance of the shift lever vs. tunnel after putting in a body lift. In a previous vehicle I experienced this, the transfer shifted fine and there was clearance to the tunnel but the rubber boot was putting pressure on the stick. In an offroad situation the transfer case moving around under torque would be enough to knock the stick from where it was supposed to be. You may have to bend the stick and/or enlarge the hole in the tunnel to rectify the problem.
Users browsing this forum: Beery and 237 guests
