It is currently Fri Oct 23, 2026 7:23 pm
Post Posted: Tue Jan 05, 2010 11:33 pm
hey got sum spoties for xmas. how do u wire it in to the hi beam i could figure out how do do it .... plz help
2''lift 31's twin locked & 6.5s
Post Posted: Tue Jan 05, 2010 11:38 pm
have you had a look in the auszookers tech topics?
http://www.auszookers.com/index.php?nam ... cle&sid=29
Post Posted: Tue Jan 05, 2010 11:44 pm
That shows you how to rewire the whole lot (headlights, Hi beam and all) with new relays and the works.
If you just wanna add spotties, this is more or less what I did (excuse dodgy quick MSpaint job)
I want my old sig back :(
Post Posted: Tue Jan 05, 2010 11:49 pm
thanks mate didnt know it had that in there
Post Posted: Tue Jan 05, 2010 11:50 pm
cool maybe we could add that diagram to the tech topic?
Post Posted: Tue Jan 05, 2010 11:53 pm
This may also assist.
http://auszookers.com/index.php?name=Fo ... light=wire
SS
Post Posted: Wed Jan 06, 2010 12:04 am
DMAC wrote:
Yep, slightly different setup but works in virtually the same way as mine does... the Ground pin on the headlight is permanent 12V.... looks a bit neater than mine too ;)
Post Posted: Wed Jan 06, 2010 12:09 am
DMAC wrote:
Ive taken the info from this thread and added it to the tech guide and taken my diagram off 8)
Post Posted: Wed Jan 06, 2010 12:12 am
Your diagram is still pretty useul though Royce, for anyone who wants to upgrade the shitty stock headlight wiring....
Post Posted: Wed Jan 06, 2010 12:23 am
X2, both there could be useful :wink:
Post Posted: Wed Jan 06, 2010 12:27 am
yeah I need to go find the old text that goes with it and make up a new article I think
Post Posted: Wed Jan 06, 2010 12:35 am
i am gunna be putting some new driving lights on my sierra next weekend
so i can take some photos and stuff on how i do it.
Vehicle: Jeep
Post Posted: Wed Jan 06, 2010 9:30 am
Ben_Sierra wrote:
Yeah after an hour of cursing and swearing :evil: and ending up with odd bits of various length wire, i finally figured out, with the help of a volt meter, that the headlights are Negative switching, and they have constant 12volts to them ! :wink: :? :roll:
FYI, if you are gonna do it yourself, make sure the power from the battery is fused, very important, and make the wires, at the very minimum, 15amp, 20 or 25 would be better, spotties use alot of amps, my standard 40amp alternator sure feels the drain at low rev's :lol: :wink:
Post Posted: Wed Jan 06, 2010 11:32 am
I know there have been a stack of different wiring diagrams put up but this is about the simplest Ive seen, and as long as the relay is switched via the 2 headlight cables it will work on either negative or positive switched vehicles.
You can also build an adapter for the headlight loom for about $5.
Geoff
Vehicle: Jeep
Post Posted: Wed Jan 06, 2010 11:50 am
Geoff
Yep that is very simple, and very easy to understand, wish i had seen this before my attempt at it, lol, oh well, they work now :wink:
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 133 guests
