It is currently Mon Jul 27, 2026 3:48 pm
Post Posted: Mon Jan 11, 2010 10:23 pm
i have 2 of these battery's and want to run a motor that will use a maximum of
55amps but will mostly be using around 25 to 40 amps. if one battery can
handle a load of 37.5 amps can 2 wired together cope with 55amps?
should i just cough up the $600 for a pair of marine battery's that will only
have half the capacity?
Post Posted: Mon Jan 11, 2010 10:25 pm
If you parallel two identical voltage batteries, you can add the currents that they an supply to get a total current rating for the setup.
I want my old sig back :(
Post Posted: Mon Jan 11, 2010 10:27 pm
That sticker appears to be talking about charging currents though?
Post Posted: Mon Jan 11, 2010 10:29 pm
Is this for an electric outboard? If you got 'em already just run 'em :lol:
150AH is pretty damn big! 8O
Post Posted: Mon Jan 11, 2010 10:35 pm
yep they are for my bow mount O/B damo. i stumbled across 6 of them :D
but did my back in lifting two of the heavy bastards :cry:
Ben_Sierra i have a 30 amp charger so every thing should be allright :D
Post Posted: Mon Jan 11, 2010 10:40 pm
Haha I bet you pinched them from the god-botherer's wind farm :lol:
Post Posted: Mon Jan 11, 2010 10:43 pm
ssshhhh haha nah they use massive 2v jobbies. the ones i scored are from big UPS things
Vehicle: jimny
Post Posted: Tue Jan 12, 2010 12:37 am
i got almost the same battery here shep, yep bloody heavy too!
mines from the UPS at BHP, if your not shoppin at the steel works, your'e payin too much!!
Post Posted: Tue Jan 12, 2010 12:41 am
i am gunna stick them up the front of me boat to balance out the big motor i have put on the back :lol:
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Tue Jan 12, 2010 12:51 am
I would be looking a AGM Battery as it will recharge a lot quicker from the Car than the Deep Cycle Batteries. These batteries can handle more abuse as well. 100Amp capacity would do
JMO though....
rob
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Tue Jan 12, 2010 1:33 am
from my understanding of batteries..
this is what i think will happen.. with that amount of current being used you should get around 3 hours of use from 1 battery (that is constant use) so double that for 2.
the 37.5a is talking about how much current the battery will take when recharging. so if you were pumping the full 37.5 into the batteries it would take 4 hours to recharge one. 10a an hour would take 15 hours.
i would use them as the specs look to be good.
just got one for my dad to suit his fridge in the car. we went with one that wasnt as powerful (AH) but would take unlimited amps on recharge. it takes around an hour to fully recharge the battery when driving the car. so when out driving when we are away camping the 30 minute drive tops it up. we have gone a whole week with no dramas. it lasts for about 3 days before the voltage cut out on the fridge turns it off (thats with no recharging)
its been a while since i had alot to do with batteries but that is what i can kind of remember.
Post Posted: Tue Jan 12, 2010 2:28 am
i probably didn't provide enough info.
the battery's will be used only for a 55lb bowmount trolling motor in my boat
they will be kept separate to the 2 battery's that power the navigation stuff
and the man sized outboard. :D apparently the electric magic bits in the
bowmount can upset the navigation stuff if given the chance.
i thought that the 37.5 max amps thing was referring to the current that the battery could handle being used from it. :oops:
Post Posted: Tue Jan 12, 2010 2:30 am
JMO though....
rob
Agred on the AGM thing, though I think you will find that being from a UPS these will be AGM batteries.
Post Posted: Tue Jan 12, 2010 2:31 am
whats AGM ?
Post Posted: Tue Jan 12, 2010 2:34 am
AGM= Absorbed Glass Matting.
Have a read through here...
http://www.fridge-and-solar.net/agm.htm
whats AGM ?
Absorbed glass matt. It refers to how they are constructed.
Users browsing this forum: Google [Bot] and 315 guests
