It is currently Sun Jul 26, 2026 7:14 am
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Mon Jan 18, 2010 11:26 pm
hi all
i have a 1990 wt sierra and have been getting a knocking noise whenever i turn the steering wheel. i notice the most when i am going slow everything under the car looks fine but i have no idea what the problem is. i can also feel it when i am driving.the steering box has quite a bit of play in it not sure if it is coming from that. any idea guys any help will be appreiated
thanks greg
Post Posted: Mon Jan 18, 2010 11:28 pm
not sure what other info i can give you guys thanks
Post Posted: Mon Jan 18, 2010 11:30 pm
maybe CV joints but just guessing
Post Posted: Mon Jan 18, 2010 11:35 pm
Jack both the front wheels up and get someone to turn the steering left to right and back..
Stick your head under bonnet and check for noises coming out of the steering box or the uni joint in the steering shaft under the brake booster.
Post Posted: Mon Jan 18, 2010 11:48 pm
got any details on the car, tyres sizes. i know i get a knocking noise ive put it down to the spring moving slightly, body creeking ect
navara on 33s. hopfully rear air locker soon
Post Posted: Tue Jan 19, 2010 1:30 am
i haven't tried that yet want 33s so i will do that tomorrow and let you guys know. i am running 31 inch tyres 2 inch sus lift and 2 inch body and climax shackles
thanks greg
Post Posted: Tue Jan 19, 2010 4:55 am
steering rag joint and or spring/shackle bushings.
Vehicle: Clown Car..
Post Posted: Tue Jan 19, 2010 1:19 pm
am going with front wheel bearings and or kingpins..while you got the front in the air see if there is any movement in the wheels by shaking it from the top and bottom of the wheel..
Also check your shock mounts..top and bottom... a loose shock will knock like a door to door salesman...
dont forget to let us know how ya go!
Post Posted: Tue Jan 19, 2010 1:40 pm
im guessing CV...
Post Posted: Tue Jan 19, 2010 1:44 pm
I'm picking spring movement. If you don't get any noise with the front wheels off the ground, stick it back on it's wheels and try again.
Post Posted: Wed Jan 20, 2010 12:15 am
well i tried it with the wheels off the ground i didnt hear any noises and everything looked fine. no movement in little uni the biscuit is fine. i will have to wait til the misses is home to test it on the ground
thanks greg
Post Posted: Wed Jan 20, 2010 12:31 am
try it wheels down and standing still, if its the springs you can pick the noise and having a bit of a ring to it
Post Posted: Mon Jan 25, 2010 1:45 am
ok i have tried all of your tips still nothing. i changed from my drop shackles to some of fatzooks extended shackles and that has seem to of fixed it. the rubber bushes on the drop shackles where a bit flogged out so it must of been that. now i have another problem. when i go to full lock turning right the back of the inner right wheel hits the spring but going left the left wheel misses by about 50mm. i will check that the rims are the same offset tomorrow (i am sure they are). the tyres are the same size. what do you guys think the problem is?
thanks greg
Post Posted: Mon Jan 25, 2010 2:04 am
thanks greg
Same pressure in both tyres?
Post Posted: Mon Jan 25, 2010 2:24 am
thanks greg
my swb used to do that as well. i fixed it by removing the diffs. :wink:
there is a thread here where it was discussed but i don't think there was a solution found.
Post Posted: Mon Jan 25, 2010 4:25 am
could it be worn tie rod ends?
Post Posted: Mon Jan 25, 2010 12:02 pm
i have the same sort of thing happening to mine now, when i do about 50 i get a real bad wobble and the front wheels shake life crazy its got a new steering box 5k klms ago but it does have some play in the steering.
My Maruti build, Click WWW
Users browsing this forum: No registered users and 36 guests
