It is currently Wed Oct 28, 2026 10:28 pm
Post Posted: Thu Dec 07, 2006 9:47 pm
I was talking to this guy that told me the mould and oil are better for the short wheel based cars because the ride isnt as hard. He also heavly recomonded the tough dog, or EF's kit, but from the stuff that was said about a lifting on a previous thread I thought old man emu (OME) was the way to go.
whats does everyone recomend??
Also whats a resonable price to pay for a kit?
Any help will be greatly appreciated. Cheers
Post Posted: Thu Dec 07, 2006 10:23 pm
the whole gas vs oil thing is a load of crap
people that say that dunno how a shock works, all the gas does is pressurise the oil so it cant foam up on rough roads and make the shock go soggy
OME struts have the runs on the board, some say tough dog are good but some say they are stiff
rears there are millions of options, the OME work well or you can go with longer from rancho or out of some car
Westie has kings springs and thinks they are ok, I think they are cheaper than OME's
I dunno about all the efs's and all that, you dont seem to see much of em in real tourers and thats what hammers the stuff
Post Posted: Thu Dec 07, 2006 11:43 pm
Cheers Royce,
I dont know to much about suspension, im just taking in all the info thats given to me and ill make a decision based on that.
:D
Post Posted: Fri Dec 08, 2006 3:13 am
didnt u tell me OME shocks r too short ? i was goin to follow ur OME springs with dunnydore and hilux dampers suggestion but im a bit confused now!
what about OME springs with suzisport dampers?
mitch
Post Posted: Fri Dec 08, 2006 12:04 pm
Granta has a vitara :wink:
Post Posted: Fri Dec 08, 2006 1:38 pm
Ive got Raised Kings 30mm all round with spring spacers from Bruce which gives me a total lift of about 60mm and then got OME front struts and OME rear shocks for extra down travel. I rekon its all good and not too expencive if you install it all your self... Its not hard..
I'd say best bang for your buck its the KING SPRINGS $310 a full set.. + OME's about $400 a set + spring spacers $100 a set + you'll need camber bolts for the front wheels to get them back to neg camber.... You can then fit 30" tyres under your vit for some more hight... I think its about 120mm higher than the standard vit. :lol:
See my website / home page for some pics of it all..
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Fri Dec 08, 2006 3:12 pm
my bad
BTW... what model hilux dampers am i askin for?
mitch
Post Posted: Fri Dec 08, 2006 3:19 pm
about 88ish
Vehicle: 75 Cruiser
Post Posted: Fri Dec 08, 2006 3:39 pm
hilux rear shocks? my 97 hilux rear shocks are two inches longer than the standard sierra ones, and the 2002 model hilux rear shocks i got are about 2 -3 inches longer than the standard sierra ones.
Post Posted: Fri Dec 08, 2006 10:51 pm
they mite be longer but do they compress as much as sierra ones? also, do all of em bolt up?? same hole size etc?
Post Posted: Sat Dec 09, 2006 3:03 am
dont worry...u already answered that question
Post Posted: Mon Dec 11, 2006 9:29 pm
sp1086
Nice pics of your vit. Cheers guys
Post Posted: Sun Apr 08, 2007 12:19 am
You know that King make the OME springs right ?
and Monroe make the dampers/struts
Post Posted: Sun Apr 08, 2007 2:09 am
why does it matter which springworks make them? they are of totally different design, OME are 5 x5mm leafs, kings are 4x8mm, OME have miltary wrap and the little slipper things too
and yes Tenneco, Monroes parent company, are the largest shock manufacturer in the world if you go to the monroe website it even has a link to the Rancho website cause they make them too
I am pretty certain you are wrong on both counts though as I have spoken to Mark King many a time about making custom springs up and he is dead against the OME leaf design and most Tenneco shocks will have Tenneco stamped on them
Post Posted: Fri Apr 13, 2007 5:11 pm
Hey sounds like you got it sussed, does having spacers effect anything, eg length of travel? Is it the only way to get more than about 30mm lift from suspension? Does anyone make springs big enough? What's the camber stuff you were talking about?
I'm just about to get a suspension lift of around about 2in. so any help would be great.
Thanks.
'94 Vitara: 2" lift, BFG 235/75R15 MT's.
Datsun 2
Post Posted: Fri Apr 13, 2007 5:21 pm
spacers do effect travel to an extent, you are effectivley raising the spring rate so you need more weight to make use of the extra uptravel you now have and the wheel only travels down to the same point due to shock length
Post Posted: Mon Apr 16, 2007 1:58 am
So a stiffer spring like King Springs wouldn't be too good? And what do you mean by 'the wheel only travels down to the same point...'?
Thanks heaps.
Datsun 2
Post Posted: Mon May 31, 2010 1:49 pm
So if you got 40mm lift in the springs, 20mm spaces... But bought Shocks for an 80mm lift would that give you wicked down travel? or just a death trap?
Peter
Users browsing this forum: No registered users and 344 guests
