It is currently Sun Nov 08, 2026 5:24 pm
Post Posted: Sun Apr 15, 2007 4:36 pm
Hi again,
Where do you get those ball type map lights? I've seen them used in overhead consuls, but I don't want the expence (ok, can't afford) of buying one of those. Just trying to light up the interior of the Zook a bit bette than the 1/2 candle power light that's there now...and also have a map light for the boss when she's navigating...
Michael
Post Posted: Sun Apr 15, 2007 5:08 pm
Interior light idea.
This may sound a bit crazy but what if you rigid up one of those small fog light's, there would be plenty of light from one but the switching on/off with the door might be a problem.
Vitara gone, tis no more. replaced by a 98 XH Falc
Vehicle: LJ20 LJ50
Post Posted: Sun Apr 15, 2007 5:15 pm
I went to super cheap and got a 12v flouro. Fantastic. $12.00 You can drive with it on and still see outside the car. As for the map raeding light you could move the factory one over to her side above her left shoulder.
Camels have nice toes
Post Posted: Sun Apr 15, 2007 10:22 pm
I have a fluro in the back of mine thats magnetic with a curly cord that lights up where I want
otherwise the flexi neck ones come from hella, not too cheap but worth it for the sanity
Post Posted: Tue Apr 17, 2007 1:28 am
I like the fluro idea...but I didn't think you'd be able to see out if it was on.
Thanks for the suggestions...
Post Posted: Tue Apr 17, 2007 1:42 am
do you have the steel 1 litre dash?
I used to have an interior light mounted in the glovebox, used to light up enough for a passenger to read a map with the lid open but not annoy the driver
Post Posted: Tue Apr 17, 2007 4:08 pm
CHECK OUT EA FALCON S PACK AT WRECKERS. THEY HAVE AN INTERIOR LIGHT IN THE MIDDLE OF THE ROOF WITH TWO SPOT LIGHTS.
Vehicle: LJ20 LJ50
Post Posted: Tue Apr 17, 2007 9:14 pm
Also the top of the range sigma had them too. You can get a whole sigme for $50
Vehicle: 75 Cruiser
Post Posted: Tue Apr 17, 2007 9:24 pm
TZAR wrote:
$50
yeah they give you $50 to take them away :)
Post Posted: Wed Apr 18, 2007 2:26 am
I do have a steel dash...1L. Putting a light in the glove box is on the agenda too....
I'm trying a cigarette lighter type map light at the moment. I've taken the plug off the base, drilled a hole in the passenger side plastic end cap on the dash. It stands up against the left-hand windscreen pillar, and can be bent forward when in use. I have to rewire it though...should look alright.
Vehicle: 87 pathfinder
Post Posted: Sat Apr 28, 2007 4:14 am
I use a super bright LED onthe end of a bit of stiff wire so I can aim it where I want covered the whole thing except the end of LED in heat shrink to tidy it up works great very small uses bugger all power
can easily read by it
drilled a hole in the bolt and jamed the wire in it to mount it
I'll get a pic when I can but kind of looks like one of those lights that ya can plug into a USB port on a laptop
If it ain't broke. I can fix that
Vehicle: Audi
Post Posted: Wed Feb 08, 2012 10:33 pm
Hey there..!! I have been following your post since last six months and I got so many useful information from here.
Thank you so much for that.
roof repair mornington
Users browsing this forum: Google [Bot] and 78 guests
