Joined: Sat May 30, 2009 11:30 pm Posts: 2770 Location: sunny coast
Vehicle: jimny
Posted: Thu Jan 28, 2010 11:25 pm
i just did the same thing but in reverse, sj70 engine in my sj51LWB. it all bolts in everything is the same except the stroke on the motor. you might have to change the carby back to the later model carb
Engine has a few different castings etc but nothing you'd notice without looking really hard.
Both being 89's the clutch should be the same.
If you swap in engine and box together you won't have to split them or worry about the clutch.
Joined: Tue Oct 13, 2009 10:30 pm Posts: 928 Location: Sunny Coast
Vehicle: 79 Lj80 stockman 94 swb Sierra
Posted: Thu Jan 28, 2010 11:56 pm
Ok thanks guys,
I thought they should both be basically the same as the build dates are only 2 months apart.
The clutch attached to the sj50 box is getting a bit tired,
I might order a new Exedy heavy duty so everything will be good when I get my gears.
Users browsing this forum: No registered users and 206 guests
