It is currently Fri Oct 23, 2026 11:35 pm
Post Posted: Fri Jan 29, 2010 1:07 pm
Ok, I have a g16a block with 1.3 head and carby.... I'm sick of my carb giving me shit sooo my thought was to put a 1.6 efi head on and do the necesary mods to go down that road??? Is this possible ?
Cheers brad
Post Posted: Fri Jan 29, 2010 1:55 pm
You can fit import Vitara TBI to an 8 valve G16 head(bolt on) or I believe there were a few Swifts with TBI on 8 valves too.
If I were you I'd sell all the bits you have and buy a G16B MPFI.
Post Posted: Fri Jan 29, 2010 9:59 pm
Cheers want33, only downside to that is the price difference of the cost of the new motor, rebuild etc to th total of all my bits. I would still be looking at 500????ish?
Vehicle: SJ80
Post Posted: Fri Jan 29, 2010 10:35 pm
Below is a photo of the g16a from my sierra with a 16 valve mpfi head on it. Keep in mind if you're doing this conversion you'll need a fuel tank that can support an in tank pump (ie coily tank) or alternatively you'll need to add a surge tank. Either way you'll need a fuel injection pump as well. Considering the amount of work - and if you're on a tight budget, for the performance increase you get, I still wouldn't discount getting a better carby and exhaust.
Post Posted: Fri Jan 29, 2010 11:06 pm
thanks alot for the info and pics, pm sent. :)
Post Posted: Fri Jan 29, 2010 11:14 pm
Well now you say that, I assume its a possibility to put a 1.6 carb on in place of the 1.3? or fuck it and go webber hahaha
Post Posted: Fri Jan 29, 2010 11:25 pm
yeah....go 100 steps backwards by using a weber carb.....
Post Posted: Fri Jan 29, 2010 11:27 pm
haha exactly..
Post Posted: Sat Jan 30, 2010 4:11 am
C'mon they aint that bad!
bigrig91 wrote:
haha exactly..
Bigrig have you driven a weber powered rig before?? What sort of stuff do you drive? Yes continual 'just about to roll your car' offroad it will be no good for but I found for the extra performance and the absolute simplicity of the carb it was worth it. Yes it did have a stall here and there although the angles wern't what you would call nothing. With the low range gears I had no problems doing the tracks at ormeau and such. In the 3 years I had it on the car I never had to touch the thing.
Dan
Post Posted: Sat Jan 30, 2010 4:31 am
hey jr, i have never driven a weber powered suzi or 4by for that matter, but a worked cortina and escort i have. so i guess i can only make assumptions about the 4x4 capabilities of them. Can i ask what size you used, i have heard of the one on ebay that is supposedly modded for wheeling.
Users browsing this forum: Google [Bot] and 105 guests
