| Author |
Message |
reallyuted
Joined: Fri Nov 14, 2008 10:30 pm Posts: 253 Location: jimboomba se QLD
 Posted: Sun Jan 31, 2010 9:28 pm |
ive been pulling apart my next project and the gear box and transfercase are both caked in about 20 years of crap  the old export spray degreaser wont cut it  ive also used oven cleaner that works good just not on paint and plastic! now im just wondering what have you guys found and kept a secret to be the best to clean them down in cheers
royce
 Posted: Sun Jan 31, 2010 9:33 pm |
Crazy Clarks sell a degreaser in an Orange and Black can that strips everything and does weird things to your skin, that and a gerni would do it
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Sun Jan 31, 2010 9:42 pm |
Diluted acid wash perhaps  Not sure how it would react on metal, it would tear a new one out of anything
_________________ Shep is a closet jimny lover!!!!
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Sun Jan 31, 2010 10:58 pm |
303zuke
 Posted: Mon Feb 01, 2010 12:04 am |
Yeah, Acid or Caustic washes will both attack the alloy.
One of those Gerni or Karcher pressure washers work well. Instead of putting detergent in the wash tank, use Kero. Works excellently and won't harm the metal. Just don't do it on the lawn or where the run-off will go down a drain. And if you've hired the washer, rinse the tank out with detergent before you send it back.
If that's too hard, do you have a Carlovers/ Aquarius carwash nearby with do-it-yourself pressure wands? They usually have a degreaser option on low pressure, but by alternating with the high pressure soap it can work well. Just soak the case in degreaser or kero before you take it down there.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Mon Feb 01, 2010 12:07 am |
KENCO SHIFT-IT.... Awesome stuff... Soak for 10-15 minutes then pressure wash and repeat if necessary.
Item will be sparkling.
lump_a_charcoal
 Posted: Mon Feb 01, 2010 12:09 am |
Yeah but it is highly corrosive, so make sure it isn't on for more than 10-15...
v.w.dave
Joined: Sun Sep 27, 2009 11:30 pm Posts: 1437 Location: The Hills Sydney
 Posted: Mon Feb 01, 2010 1:05 am |
last option take it to your local head shop and get them to dip it in there cold acid dip for a few mins. It will look good as new. But you will have to re seal the box afterwords.
_________________ Snap-On Dealer let me know if you need anything.
zookprojectfnq
Joined: Fri May 15, 2009 11:30 pm Posts: 260 Location: Cairns
 Posted: Mon Feb 01, 2010 1:17 am |
There's 2 types of degreaser we use at work and thats gen solve and shock treatment. they both are pretty awesome. the shock treament being strongest. Dont spray either in a kero gun, it will leave you breathless. brings ali housings up like its been dipped at a reco shop. you can buy it in 5l,20l or 205s
reallyuted
 Posted: Mon Feb 01, 2010 2:05 am |
cheers guys i wasnt expecting such a good turn out
ill see which one i can find near me
lump_a_charcoal
 Posted: Mon Feb 01, 2010 1:06 pm |
Bunnings and most car shops sell the KENCO stuff...
