It is currently Tue Jul 28, 2026 12:00 am
Post Posted: Sat Feb 13, 2010 6:45 pm
I have tacked in the 1.3 mounts. And the measurements for the 1.3 swb w/t are different to where my engine sits i my n/t lwb by about 25mm but the gear box is bolted up, is there a differnce between the chassis?
secondly i didnt take much notice when removing the engine and i cant remember if the engine leans toward the passenger side is this right
sorry about them being sideways if you need more let me know
Post Posted: Sat Feb 13, 2010 8:54 pm
Carby should sit DEAD LEVEL.
Post Posted: Sat Feb 13, 2010 9:15 pm
that means it needs to be tilted the drivers side why would it lean over if the mounts are sitting on the chassis almost perfectly
Post Posted: Sat Feb 13, 2010 10:18 pm
Is the lean in the springs?
Post Posted: Sat Feb 13, 2010 10:47 pm
the lean is definitely the engine, ill cut the mounts back off and have another attempt when. I had another look the lh mount is sitting different to my swb one
Post Posted: Sun Feb 14, 2010 1:14 am
when i changed chassis mounts on my maruti, i just bolted the 1.3 mounts to the motor and sat it in position with the box bolted in then tacked them up, removed the motor and box and then fully welded them.
this way you can tweek the mounts a little to get it where you want
i did measure a 1.3 wt swb chassis for referance but they have a differant lenght jack shaft(to the maruti) and sit back about 20 to 25mm.my 1.6 sits pretty close to the fire wall (about 10mm at closest point) compared to my mates 1.6 (about 30mm at closest) in a swb
also my gear stick fouled on the bottom of the hole for it to come through but only just. with the rubber boot bolted down it would pop out of 2nd and 4th. i cut 5mm out of the boot surrond steel bit at the bottom and its good now, also i mounted the 1ltr radiator on the front of the 1ltr rad mounts hope some of this is a help
cheers wayne
Post Posted: Sun Feb 14, 2010 1:29 am
My engine is sitting approx 25mm further back than in my swb that's on the mounts I'm doing it the same way you explained so this all makes sence Now thanks for that mate appreciate it.
So just to clarify the maruti which mine is the gbox mounts sits approx 25mm further back than a stock Sierra and runs a shorter Jack shaft?
Post Posted: Sun Feb 14, 2010 1:59 am
yes mine did. i had a quick look at my motor and it does lean to the passenger side only just tho (could be the drink to :cheers:)
Post Posted: Sun Feb 14, 2010 2:18 am
mines leaning quite a bit the top of the carby is leaning over
Im gonna put the engine to the side for now and do my w/t diffs im looking at another engine so ill see what comes of that
Post Posted: Sun Feb 14, 2010 5:31 am
Didn't I tell you how to fix that Friday night?? :? :? :? :?
Post Posted: Sun Feb 14, 2010 8:42 pm
No u must of thought it!
Post Posted: Mon Feb 15, 2010 1:45 am
Or you forgot!!
Has to do with the r/h eng mount, the one on the chassis, ring any bell's????
Post Posted: Mon Feb 15, 2010 2:00 am
cant remember lol tell again?
Post Posted: Mon Feb 15, 2010 2:12 am
cheers wayne
He's told you how, you replied that it made sence.
So what part are you unclear on??
Users browsing this forum: No registered users and 361 guests
