It is currently Sat Oct 24, 2026 11:18 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
Post Posted: Sat Feb 20, 2010 1:53 am
Brett wrote:
why would you have your hubs locked in on a hard surface to make the steering heavy :lol:
Ummmm maybe rock crawling, i don't know....
MR1JZ, ping BenT a PM about his power steering wedge seeing you stock piling bits.
Post Posted: Sat Feb 20, 2010 4:15 am
ill just up my tricep workouts at the gym :P
95 W/T - Got a few bits
Post Posted: Sat Feb 20, 2010 12:46 pm
If you're on hard surfaces and the hubs are locked put it in 4x2 and you won't even know it's there, I don't even unlock my hubs unless I'm going more than 20km on road. Only time I don't like it's affect on the steering is if I try to go fast in 4x4, just means I need to put it in H2 then.
Post Posted: Sat Feb 20, 2010 1:16 pm
i dunno about other people but my locker unlocks when i am on hard surfaces
and i turn the steering wheel, that's why lockers are better then welding or spools.
Post Posted: Sat Feb 20, 2010 1:53 pm
Looks like im about to find out what locked front and rear feels like. Just ordered CrMo shafts, cv's and lockrite with couplers.
I have lockrite in the rear using the old sidegear method and it seems to work well. Should i bother swapping the sidegear lockrite into the front, and the new coupler lockrite in the rear?
Post Posted: Sat Feb 20, 2010 3:49 pm
If you are happy with it in the rear I would just leave it and put the new one in the front.
I have noticed my steering gets stiff when rock crawling, with the tyres at 5psi and jammed in a hole and I need to turn, even with power steer. But it usually is just a matter of getting the tyres to roll just enough so that the locker can unlock. Id be stuffed trying to do it with 12.5 inch tyres and no PS.
Post Posted: Fri Apr 02, 2010 2:15 pm
Need help here guys. I have a Lockrite 1530 with couplers sitting here ready to be fitted to a diff, and crmo 26spline axles/CV's ready to be fitted too.
I cant get a clear answer, will 1530 Lockrite with couplers fit in a 89ish WT 2-pin front diff?
If it doesnt, do i just fit locker to a spare 4pin rear diff and then shove it in the front axle, or do you just swap the 4pin centre and crownwheel over to the 2pin housing?
Also, dammit i cant decide wether to just sell the lockrite and buy a pAyRB airlocker for the rear, then use it in the front with the 26spline crmo axles.
Post Posted: Fri Apr 02, 2010 3:21 pm
1510 lockright goes into a 2 pin wt front diff. it is an outerlimites internet myth
that they don't fit i know this as i have one in the front of my car which has a
complete SJ70 front diff in it.
Red89 wrote:
X2 to what Shep said about fitting in a 2 Pin front end, as I have a 1510 in the front of my WT, I bought the 26 spline side gears later on when I went cromoly. They are awsome locked front and rear but I cheated and put in PS at the same time.
The 1530 simply replaces the side gears so I dont see it being any different :wink:
Post Posted: Sat Apr 03, 2010 12:29 am
Yeh im just making sure that its possible, so much conflicting bloody info.
Users browsing this forum: No registered users and 625 guests
