| Author |
Message |
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Sat Mar 06, 2010 5:48 pm |
Hey guys, I recently replaced the rear housing on my gearbox and in my haste didnt really pay too much attention to what the inside looked like  Anyway I swapped over all the parts that the new case didnt have including the bolt on the side in the pic below. Now when I go to select reverse however the flap for the reverse wont lift up/ rotate at all meaning no reverse gear. I have worked out that the problem is that bolt, if it is only half way in ( like in the pic ) or completely out it is fine.
Now my question what is the bolt for ? Can I cut it in half and use it to plug the hole or does it need to be in there ?
paulv
Joined: Mon Jun 01, 2009 11:30 pm Posts: 331 Location: Adelaide
Vehicle: SJ80
 Posted: Sat Mar 06, 2010 5:58 pm |
Are you sure there is supposed to be a bolt in there?
Where is your reverse switch - that controls the revesing lights?
unique_seek
Joined: Mon Feb 16, 2009 10:30 pm Posts: 537 Location: Sunny Coast
What gearbox is that on?
_________________ Coily GTI Turbo...thats right its a coily!!
unique_seek
 Posted: Sat Mar 06, 2010 5:59 pm |
yeah it may be for your reverse light switch?
BlueSuzy
 Posted: Sat Mar 06, 2010 6:25 pm |
unique_seek wrote: yeah it may be for your reverse light switch?
no.
unique_seek
 Posted: Sat Mar 06, 2010 6:27 pm |
any suggestions?
Red89
 Posted: Sat Mar 06, 2010 6:30 pm |
BlueSuzy wrote: unique_seek wrote: yeah it may be for your reverse light switch? no.
A reverse light switch would make sense but they are bigger and on the front half of the case
And sorry its a 5speed Sierra box.
unique_seek
 Posted: Sat Mar 06, 2010 6:34 pm |
just checked mine,I have the bolt too?maybe its the wrong bolt?
BlueSuzy
 Posted: Sat Mar 06, 2010 6:37 pm |
Just checked my lwb.. 1.3 5sp
The bolt is bolted in..
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sat Mar 06, 2010 7:03 pm |
That bolt is definately supposed to be there..
It is part number 09135-08006 (M8X20mm) and it is the reverse shift rod locator.
To fit it you may have to jiggle the shaft in and out of reverse and/or rotate it.
Red89
 Posted: Sat Mar 06, 2010 8:39 pm |
Dam! not what I wanted to hear.
Cheers mate I'll go jiggle see what I can find.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sat Mar 06, 2010 8:59 pm |
so where is the reverse light? mine is tuffed on my lwb....
Red89
 Posted: Sat Mar 06, 2010 9:37 pm |
31zook wrote: so where is the reverse light? mine is tuffed on my lwb....
There is 2 or 3 black plugs ( about the size of 'C" batteries ) on the top half of the front part of the case with wires that go up into the engine bay it will be one of these.
Can some one tell me, using a screw driver I can move the reverse rod forward into reverse but I can also move it backwards past neutral. Is that what this bolt is ment to prevent so when you are taking it out of reverse the rod doesnt go past the neutral point in the box ?
I have the bolt 99% of the way in but when I tighten it up it jams the rod up
want33s
 Posted: Sat Mar 06, 2010 9:43 pm |
Red89 wrote: Can some one tell me, using a screw driver I can move the reverse rod forward into reverse but I can also move it backwards past neutral. Is that what this bolt is ment to prevent so when you are taking it out of reverse the rod doesnt go past the neutral point in the box ?
That's right.. It's so you don't engage reverse and 5th at the same time.
That bolt should have a washer on it.... Does yours?
If not... Fit a washer and it should be good.
Red89
 Posted: Sun Mar 07, 2010 2:45 am |
want33s wrote: Red89 wrote: Can some one tell me, using a screw driver I can move the reverse rod forward into reverse but I can also move it backwards past neutral. Is that what this bolt is ment to prevent so when you are taking it out of reverse the rod doesnt go past the neutral point in the box ?
That's right.. It's so you don't engage reverse and 5th at the same time. That bolt should have a washer on it.... Does yours? If not... Fit a washer and it should be good.
Sounds like a plan, cheers
oozuk
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1452 Location: bethania QLD
 Posted: Sun Mar 07, 2010 1:49 pm |
want33s wrote: That bolt is definately supposed to be there.. It is part number 09135-08006 (M8X20mm) and it is the reverse shift rod locator. To fit it you may have to jiggle the shaft in and out of reverse and/or rotate it.
X 2 that's exactily what it is
_________________ building a bling zook .......will it ever be finis
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Sun Mar 07, 2010 2:50 pm |
ok i know what it is.. i had this issue when i was playing with my box the other day..
there is a little coller on the rev/5th linkage, (see pic)
it can flip over and make it impossible to get gears with the bolt in..
take bolt out, flip over, put bolt back in!
i can get a pic of box without extension housing to show u if you would like
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
jonno_racing
 Posted: Sun Mar 07, 2010 2:52 pm |
Red89
 Posted: Sun Mar 07, 2010 3:33 pm |
jonno_racing wrote: ok i know what it is.. i had this issue when i was playing with my box the other day.. there is a little coller on the rev/5th linkage, (see pic) it can flip over and make it impossible to get gears with the bolt in.. take bolt out, flip over, put bolt back in! i can get a pic of box without extension housing to show u if you would like
Yer I worked out the bolt was hitting on that collar, a pic would be great if you can
jonno_racing
 Posted: Sun Mar 07, 2010 3:45 pm |
jonno_racing
 Posted: Sun Mar 07, 2010 3:53 pm |
jonno_racing
 Posted: Sun Mar 07, 2010 3:54 pm |
Red89
 Posted: Sun Mar 07, 2010 6:20 pm |
Cheers mate helped heaps.
It turns out the bolt is too long for the box for some reason  When ever I tightened it it would push the rod across into the 3rd/4th rod, however it is on there now with an extra washer and just over finger tight and I have all 6 gears working again. Thanks everyone
